path: root/configs/iNet_3F_defconfig
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05sunxi: usb: USB_MUSB_SUNXI move to musb-new KconfigPaul Kocialkowski
Now that the musb-new driver has a Kconfig, we can move Kconfig options to enable controllers to it, so that it's easier in e.g. menuconfig. In addition, this allows declaring support for USB_MUSB_HOST/GADGET in defconfigs instead of the USB_MUSB_SUNXI controller, that will get selected automatically when needed. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-04-15sunxi: iNet 3F supportPaul Kocialkowski
The iNet 3F is an A10 tablet with 1GiB RAM and a 1024x768 screen. Also see: http://linux-sunxi.org/INet_3F Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
