path: root/configs/hsdk_defconfig
2018-05-24ARC: enable debug uart for HSDK and AXS10x boardsEugeniy Paltsev
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-04-17ARC: HSDK: Fix CPU frequency valueEugeniy Paltsev
CPU on HSDK board runs at 500MHz after preloader so fix wrong CPU frequency value in hsdk_defconfig. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-04-02ARC: HSDK: Enable SPI flash supportEugeniy Paltsev
HSDK board has sst26wf016 SPI flash IC which we want to support. Add SPI controller, CS-gpio and SPI flash nodes to hsdk device tree. Enable corresponding options in hsdk defconfig. For SPI write functionality to work we need [1] which adds support of sst26xxx ICs. [1] https://patchwork.ozlabs.org/project/uboot/list/?series=35796 Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-04-02ARC: HSDK: Add platform-specific commandsEugeniy Paltsev
This patch add support of hsdk platform-specific commands: hsdk_clock set - set clock from axi_freq, cpu_freq and tun_freq environment variables/command line arguments hsdk_clock get - save clock frequencies to axi_freq, cpu_freq and tun_freq environment variables hsdk_clock print - show CPU, AXI, DDR and TUNNEL current clock frequencies. hsdk_clock print_all - show all currently used clock frequencies. hsdk_init - setup board HW in one of pre-defined configuration (hsdk_hs34 / hsdk_hs36 / hsdk_hs36_ccm / hsdk_hs38 / hsdk_hs38_ccm / hsdk_hs38x2 / hsdk_hs38x3 / hsdk_hs38x4) hsdk_go - run baremetal application on hsdk configured by hsdk_init command. This patch changes default behaviour of 'bootm' command: now we are able to set number of CPUs to be kicked by setting 'core_mask' environment variable before 'bootm' command run. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-01-19ARC: HSDK: Hang on panicEugeniy Paltsev
As HSDK is a development board it is better to hang on panic instead of reset the board when panic occurs. That way we preserve a state of HW for possibility to do post-mortem debug via JTAG. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-29arc: Add support for HS Development Kit boardAlexey Brodkin
ARC HS Development Kit board is a new low-cost development platform sporting ARC HS38 in real silicon with nice set of features such as: * Quad-core ARC HS38 with 512 kB L2 cache and running @1GHz * 4Gb of DDR (we use only lowest 1Gb out of it now) * Lots of DesigWare peripherals * Different connectivity modules: - Synopsys HAPS HT3 - Arduino-compatible connector - MikroBUS This initial commit supports the following peripherals: * UART (DW 8250) * Ethernet (DW GMAC) * SD/MMC (DW Mobile Storage) * USB 1.1 & 2.0 Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
