Convert the hikey to use DM_USB and DM_ETH.
Conversion based on rpi as it has a similar DWC config.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Current Hikey configuration allows us to store u-boot environment on uSD
card. But this will be useless if uSD card is not inserted, hence use
the onboard eMMC memory for storing environment at Boot1 partition.
While we are at it, let's increase the boot delay to 10s also.
Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
Convert HiSilicon HI6220 MMC driver based on DWMMC IP to driver
model.
[trini: Enable this on poplar]
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that
they can be modified via Kconfig. Migrate all existing users to the new
values.
CONFIG_ENV_IS_IN_FAT
This change migrates the USB_DWC2 configuration item to Kconfig
and runs moveconfig to adjust header files and defconfig.
Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com>
Split off into a separate patch:
Ran moveconfig to migrate other boards:
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
96boards CE devices such as the DragonBoard and Hikey devices have numerous
mezzanine options some of which need overlays from the beginning so it makes
sense to enable device tree overlays.
Now that these symbols are in Kconfig, migrate all users. Use imply on
a number of platforms that default to having this enabled. As part of
this we must migrate some straglers for CMD_FAT and DOS_PARTITION.
CONFIG_CMD_ZIP is not defined by any board. I am moving
CONFIG_CMD_UNZIP to defconfig files except UniPhier SoC family.
I am the maintainer of UniPhier platform, so I know "select CMD_UNZIP"
is better for this platform.
Acked-by: Michal Simek <michal.simek@xilinx.com>
Acked-by: Ryan Harkin <ryan.harkin@linaro.org>
Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
CONFIG_BOARD_EARLY_INIT_F
Move (and rename) the following CONFIG options to Kconfig:
CONFIG_EXYNOS_DWMMC (renamed to CONFIG_MMC_DW_EXYNOS)
CONFIG_HIKEY_DWMMC (renamed to CONFIG_MMC_DW_K3)
CONFIG_SOCFPGA_DWMMC (renamed to CONFIG_MMC_DW_SOCFPGA)
The "HIKEY" is a board name, so it is not suitable for the MMC
controller name. I am following the name used in Linux.
This commit was generated as follows:
[1] Rename the config options with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e '
s/CONFIG_EXYNOS_DWMMC/CONFIG_MMC_DW_EXYNOS/g
s/CONFIG_HIKEY_DWMMC/CONFIG_MMC_DW_K3/g
s/CONFIG_SOCFPGA_DWMMC/CONFIG_MMC_DW_SOCFPGA/g
[2] Commit the changes
[3] Create the entries in drivers/mmc/Kconfig
(with default y for EXYNOS and SOCFPGA)
[4] Run the following:
tools/moveconfig.py -y -r HEAD MMC_DW_EXYNOS MMC_DW_K3 MMC_DW_SOCFPGA
[5] Sort and align drivers/mmc/Makefile for readability
[6] Clean-up doc/README.socfpga by hand
This commit was created as follows:
[1] Rename the option with the following command:
-type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g'
[2] create the entry for MMC_DW in drivers/mmc/Kconfig
(the prompt and help were copied from Linux)
[3] run "tools/moveconfig.py -y MMC_DW"
[4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry
[5] Clean-up doc/README.socfpga by hand
A number of platforms had been using the distro default feature before
it was moved to Kconfig but did not enable the new Kconfig option when
it was enabled. This caused a regression in terms of features and this
introduces breakage when more things move to Kconfig.
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Currently only the serial pl01x driver is using DT,
and the other drivers still use platform data but
as more DT lands in the upstream kernel the aim is
to migrate the other drivers over to DT as well to
have a fully DT configured hikey u-boot.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
