path: root/configs/hikey960_defconfig
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28configs: Resync with savedefconfigTom Rini
2019-08-14configs: Resync with savedefconfigTom Rini
2019-08-11board: hisilicon: Add support for Hikey960 boardManivannan Sadhasivam
This commit adds board support for Hikey960 board from Hisilicon. This board is one of the Consumer Edition boards of the 96Boards family powered by Kirin960 SoC. More information about this board can be found in 96Boards website: https://www.96boards.org/product/hikey960/ The initial supported/tested devices include: - Debug serial - SD With these support, it's good enough for loading Linux Kernel from SD. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
