path: root/configs/harmony_defconfig
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-01tegra: Convert MMC to use driver model for operationsSimon Glass
Enable CONFIG_DM_MMC_OPS and CONFIG_BLK for all Tegra devices. This moves Tegra to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-05video: tegra: Move to using simple-panel and pwm-backlightSimon Glass
We have standard drivers for panels and backlights which can do most of the work for us. Move the tegra20 LCD driver over to use those instead of custom code. This patch includes device tree changes for the nvidia boards. I have only been able to test seaboard. If this patch is applied, these boards will also need to be synced with the kernel, and updated to use display-timings: - colibri - medcom-wide - paz00 - tec Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-04-01Migrate CONFIG_ULPI* to KconfigMateusz Kulikowski
Move CONFIG_USB_ULPI* from headers to defconfigs for boards that use it. Also - add CONFIG_USB where necesarry - all boards use it, but some are not defining it explicitly. Affected boards: colibri_t20, harmony, mcx, mt_ventoux, twister, zynq_(picozed, zc702, zc706, zed, zybo) Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-16tegra: Convert CONFIG_PWM_TEGRA to KconfigSimon Glass
Move this option to Kconfig and clean up the header files. Adjust the only user (the LCD driver) to work with the new driver. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Convert tegra20 LCD driver to driver modelSimon Glass
Move this driver over to use driver model. This involves rearranging the code somewhat. The effect is that everything is run from the probe() method. Boards which use this are fixed up, but only seaboard is tested. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Rename CONFIG_VIDEO_TEGRA to CONFIG_VIDEO_TEGRA20Simon Glass
This option refers only to the tegra20 video driver, so name it as such to avoid confusion with tegra124. Also move this option to Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-08-30tegra: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Tegra board select menu to tegra/Kconfig. Insert the Tegra SoC select menu between the arch select and the board select. Architecture select |-- Tegra Platform (Tegra) |- Tegra SoC select (Tegra20 / 30 / 114 / 124) |- Board select Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows: config TEGRA bool select SPL Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
