path: root/configs/h2200_defconfig
2016-11-23serial: pxa: use kconfig for serial configurationMarcel Ziswiler
Migrate the PXA serial driver to be configured via Kconfig. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Marek Vasut <marex@denx.de>
