path: root/configs/h2200_defconfig
2017-05-22FIT: Rename FIT_DISABLE_SHA256 to FIT_ENABLE_SHA256_SUPPORTTom Rini
We rename CONFIG_FIT_DISABLE_SHA256 to CONFIG_FIT_ENABLE_SHA256_SUPPORT which is enabled by default and now a positive option. Convert the handful of boards that were disabling it before to save space. Cc: Dirk Eibach <eibach@gdsys.de> Cc: Lukasz Dalek <luk0104@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-23serial: pxa: use kconfig for serial configurationMarcel Ziswiler
Migrate the PXA serial driver to be configured via Kconfig. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Marek Vasut <marex@denx.de>
