CONFIG_SYS_BOOTM_LEN
As part of this, rework error handling in boot/bootm.c so that we pass
the buffer size to handle_decomp_error as CONFIG_SYS_BOOTM_LEN will not
be available to host tools but we do know the size that we passed to
malloc().
Cc: Soeren Moch <smoch@web.de>
CONFIG_PCIE_IMX
CONFIG_LBA48
CONFIG_SYS_64BIT_LBA
CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS
CONFIG_SYS_SPL_ARGS_ADDR
In doing so, we also consistently use this variable for SPL_OS_BOOT and
not CONFIG_SYS_FDT_BASE in some cases.
CONFIG_SYS_SPL_MALLOC_SIZE
CONFIG_SYS_SPL_MALLOC_START
We introduce a default value here as well, and CONFIG_SYS_SPL_MALLOC to
control if we have a malloc pool or not.
Update the Kconfig entry to have the correct defaults for i.MX6
platforms, and move the existing large comment from imx6_spl.h to
doc/imx/common/imx6.txt so that it's not lost.
CONFIG_SPL_STACK
CONFIG_SYS_PBSIZE
CONFIG_SYS_MAXARGS
Use the common GSC driver.
This allows us to do some additional cleanup:
- use the GSC driver functions
- move waiting for the EEPROM to the SPL int (it will always be ready
after this)
- move eeprom functions into eeprom file and elimate GSC_I2C_BUS
- eliminate some redundant EEPROM reads (the EEPROM must be read in
SPL before relocation, in SPL after relocation, and in U-Boot init.
All subsequent uses can use the global structure)
- remove unnecessary header files and alphabatize includes
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
convert to DM_I2C for U-Boot while leaving SPL legacy I2C:
- Move I2C config from common to SPL
- Move PMIC config from common to SPL (no need to re-configure pmic)
- add DM_I2C support to eeprom/gsc functions shared by SPL and U-Boot
Falcon mode is very useful in improving boot speed. A question that
Falcon mode asks is "Where do I look for the kernel". With MMC boot
media, the correct answer is CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR.
The scope of this patch is to move this to Kconfig.
It is possible for a system to support Falcon mode from NOR but not
MMC. In that case, mmc_load_image_raw_os() would not be used. To
address this, conditionally compile mmc_load_image_raw_os() when
SPL_FALCON_BOOT_MMCSD, instead of SPL_OS_BOOT.
Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
[trini: Move spl_start_uboot to its own guard in spl_mmc.c, rerun migration]
CONFIG_VIDEO_LOGO
Note that this option depends on CONFIG_DM_VIDEO now, since cfb_console is
deprecated. The only relevant code is now in splash.c
Drop the check for DM_VIDEO in that file.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_I2C_EDID
CONFIG_I2C_EEPROM
After mxc_ipuv3 DM_VIDEO conversion showing splash image
doesn't work. Fix this by adding new requirements:
- splashimage env variable.
- CONFIG_SPLASH_SCREEN
- CONFIG_CMD_BMP
Enable additional USB ethernet devices.
Add watchdog support for U-Boot
Add part command for obtaining info about disk partitions.
No iMX platforms have supported ATAG-based booting. They have however
re-used the CONFIG_SERIAL_TAG option as a way to enable support of
reading the OTP fuses and setting the serial# environment variable in
some cases. Change the warp7 support to use this symbol, use this for
updating the rest of the imx7 code, and update the imx8 conditionals.
Cc: Fabio Estevam <festevam@gmail.com>
Cc: NXP i.MX U-Boot Team <uboot-imx@nxp.com>
CONFIG_POWER_I2C
CONFIG_POWER_LEGACY
They are handled at the same time due to a dependency between them.
Update the Makefile rule to use legacy power only in U-Boot proper.
Unfortunately a separate rule is needed in SPL to be able to build
legacy power. Add SPL related symbols for both, to allow for SPL-only
usage.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: More SPL related cleanups, reword commit message]
Rename these options so that CONFIG_IS_ENABLED can be used with them.
[trini: Fixup some incorrect renames]
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
- Provide a default Kconfig value of the default script
- Largely continue to define this via the board Kconfig file
- For the boards that select a script based on defconfig rather than
TARGET, keep this within the defconfig.
CONFIG_SYS_I2C_MXC
CONFIG_SYS_I2C_MXC_I2C1
CONFIG_SYS_I2C_MXC_I2C2
CONFIG_SYS_I2C_MXC_I2C3
CONFIG_SYS_I2C_MXC_I2C4
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
Use device-tree LED config instead of hard-coded board-specific config.
Rename this option so that CONFIG_IS_ENABLED can be used with it.
Add Legacy U-Boot image support needed to boot a uImage.
For some time now having USB_KEYBOARD support has caused usb to be
initialized on boot. To allow for a quicker bootup we don't want this
for Ventana and don't really need USB keyboard support so remove it.
Enable driver model support for FEC ethernet which allows us to remove
the iomux and board_eth_init function. Replace the toggling of the ethernet
phy reset with dt configuration.
Enable driver model support for PCI which allows us to remove the
eth1000_initialize() call. Additionally enable PCI_INIT_R to scan for
PCI devices on init such as the e1000 that is present on the GW552x.
Convert board_pci_fixup to use dm callback and remove pcidisable env
variable which is not supported for DM_PCI and thus leave PCI always
enabled during init.
Enable driver model for SPI which allows us to remove the iomux
and init.
Enable driver model support for MMC and SATA.
Note that DM_MMC requires aliases for your mmc devices so
they are added to the dts. Linux does not support enumerating mmc
devices by alias so these are not present in the Linux dts.
Note that we still need board_mmc_init() and board_mmc_getcd() for
not DM SPL to support MMC.
Enable dm support for USB (which also requires dm support for fixed
regulators used for vbus enable) and remove usb iomux which is no
longer needed.
We can remove the handling of otgpwr_en gpio as this is defined in
dt as usbotg vbus-supply but we need to keep the handling of
USB_HUB_RST# for boards that have a USB HUB as that isn't defined in
the dt's currently.
Once the IMX6 pinctrl driver is added UART is fully using driver mode
so we no longer need to config and initialize it.
In preparation for dm conversion convert to OF_CONTROL by adding FIT image
support and multi dtb.
Add a board_fit_config_name_match to match the dtb based off of EEPROM
model.
Done via moveconfig.py
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
For 2020.10
- mx6: SOCs user selectable
Fix for imx6q_logic
Some DM conversion
- mx7: introduce secondary boot device
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/720918010
We have a number of platforms that are a combination of a carrier board
and System-on-Module (SoM) that in turn allows for the board to have
different SoCs on it. In some cases, this is handled via board-specific
Kconfig options. In other cases we make use of
CONFIG_SYS_EXTRA_OPTIONS. This latter case however can lead to invalid
configurations as we will not in turn get options that in Kconfig are
selected by or depend on that setting.
To resolve this, make the SoC option a choice in Kconfig and make boards
depend on what they can support. This change opens us up for further
clean-ups in the cases where a single CONFIG_TARGET_xxx can support
different SoCs and today they do not, or do not cleanly do so.
Reported-by: Matt Porter <mporter@konsulko.com>
Cc: "NXP i.MX U-Boot Team" <uboot-imx@nxp.com>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Cc: Igor Opaniuk <igor.opaniuk@toradex.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Andreas Geisreiter <ageisreiter@dh-electronics.de>
Cc: Ludwig Zenz <lzenz@dh-electronics.de>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Akshay Bhat <akshaybhat@timesys.com>
Cc: Ken Lin <Ken.Lin@advantech.com.tw>
Cc: Ian Ray <ian.ray@ge.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
Cc: Simone CIANNI <simone.cianni@bticino.it>
Cc: Adam Ford <aford173@gmail.com>
Cc: Marcin Niestroj <m.niestroj@grinn-global.com>
Cc: "Eric Bénard" <eric@eukrea.com>
Cc: Baruch Siach <baruch@tkos.co.il>
Cc: Jason Liu <jason.hui.liu@nxp.com>
Cc: Ye Li <ye.li@nxp.com>
Cc: Eric Nelson <eric@nelint.com>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Parthiban Nallathambi <parthiban@linumiz.com>
Cc: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Niel Fourie <lusus@denx.de>
Cc: Martyn Welch <martyn.welch@collabora.com>
Cc: Richard Hu <richard.hu@technexion.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Boris Brezillon <bbrezillon@kernel.org>
Cc: Arkadiusz Karas <arkadiusz.karas@somlabs.com>
Cc: Breno Lima <breno.lima@nxp.com>
Cc: Francesco Montefoschi <francesco.montefoschi@udoo.org>
Cc: Silvio Fricke <open-source@softing.de>
Tested-by: Matt Porter <mporter@konsulko.com> [colibri_imx6]
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
CONFIG_NETCONSOLE
