The mvsata_ide driver was due for DM conversion by v2019.07. As that
has long passed, remove the driver and disable it in the boards which
had enabled it.
CONFIG_NETCONSOLE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_BZIP2
CONFIG_GZIP
CONFIG_LZO
CONFIG_ZLIB
CONFIG_LZMA
CONFIG_LZO
Have this symbol follow the pattern of all other such symbols.
This patch also removes a TODO from the code.
Reviewed-by: Chris Packham <judge.packham@gmail.com>
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig
parameters; only for the ARC architecture. This patch turns these two
parameters into Kconfig items everywhere else they are found.
All of the include/configs/* and defconfig changes in this patch are
for arm machines only. The Kconfig changes for arc, nds32, riscv,
and xtensa have been included since these symbols are found in code
under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined
include/configs/* or defconfigs for these architectures exist which
include these symbols.
These results have been confirmed with tools/moveconfig.py.
Acked-by: Alexey Brodkin <abrodkin@snopsys.com>
Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
[trini: Re-migrate for a few more boards]
Enable CONFIG_DM_USB and where possible CONFIG_BLK.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Tested-by: Leigh Brown <leigh@solinno.co.uk>
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Now that there is DM support in the RTC_MV driver update board configs
to use it.
Import the dts files from Linux 4.17 and enable CONFIG_OF_CONTROL.
Add Kconfig for MVGBE and update boards to select this.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_LZMA
CONFIG_CMD_JFFS2
CONFIG_CMD_IDE
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
[trini: default y if DM_RTC, re-sync]
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
This commit was created as follows:
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
For Marvell plugs, move the configuration of DHCP, NAND/SF, PING
and USB commands, and HUSH_PARSER into the _defconfig file, rather
than the include/configs/*plug.h files.
This avoids compiler warnings of duplicate definitions if the
option is selected in the .config, but also defined in the
include/configs/*plug.h file.
Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
