path: root/configs/gt90h_v4_defconfig
2015-10-20sunxi: power: Change A23/A33 aldo1 default voltage to 3.0VHans de Goede
On A23 / A33 boards aldo1 is used for VCC-IO and should be 3.0V, make this the default. Note that this does not cause any functional changes since all sun8i board defconfig-s already contained: CONFIG_AXP_ALDO1_VOLT=3000 . Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-10-20sunxi: power: Change A23/A33 VDD-SYS default from 1.2V to 1.1VHans de Goede
Change the axp223 dcdc2 / VDD-SYS default from 1.2V to 1.1V, 1.1V is the value recommended by Allwinner and is what most fex files specify. This has been tested on a number of A23/A33 tablets including on an A23 Ippo-q8h-v1.2 PCB tablet which has a fex file which specifies 1.2V (which is where our original 1.2V default comes from). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-10-20sunxi: power: Make all voltages configurable through KconfigHans de Goede
On boards with axp221/223 pmic-s we already allow configuring most voltages. Make the Kconfig options for these also apply to boards with axp152 / axp209 pmic-s and extend them to configure all voltages. The Kconfig defaults are chosen so that this commit does not introduce any functional changes. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-31sunxi: Add support for gt90h-v4 tabletsHans de Goede
The gt90h is a pcb found in generic 9" tablets with an A23 soc, 1G RAM and 8G nand, rtl8723as usb wifi, 1 micro usb port and 1 micro sd slot. The pmic setup on this board is somewhat special, dcdc2 MUST be set to 1.1V instead of the usual 1.2V otherwise the board is very unstable. aldo1 is used to power the micro sd slot, dldo1 is used for wifi. This commit adds a defconfig + dts (as submitted to the kernel) for the gt90h-v4 pcb. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
