path: root/configs/glacier_ramboot_defconfig
2015-02-12powerpc: ppc4xx: Change from OF_SEPARATE to OF_EMBEDStefan Roese
This is necessary, as ppc4xx has the reset vector located at the end of the U-Boot image. This needs to be flashed to the end of the NOR flash. Adding the dtb to the main U-Boot image will break booting on ppc4xx. This patch now embeds the dtb in the U-Boot image instead. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Use CONFIG_OF_CONTROL for canyonlands boardsSimon Glass
Enable CONFIG_OF_CONTROL so that U-Boot on these three boards uses a device tree for its configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Add ramboot config for glacierSimon Glass
Add a new ramboot config for glacier so that it is possible to test U-Boot loaded over Ethernet instead of using JTAG. Signed-off-by: Simon Glass <sjg@chromium.org>
