path: root/configs/ge_bx50v3_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-28configs: Resync with savedefconfigTom Rini
2020-02-09board: ge: bx50v3: use DM for uartRobert Beckett
Remove legacy uart pad and iomux code Enable DM serial and mxc uart Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-02-09board: ge: bx50v3: Enable DM PWM for backlightRobert Beckett
Add backlight and panel devicetree definitions Use UCLASS_PANEL to enable backlight via display enable handler Remove old explicit gpio code for handling backlight Use cls command to initiate display in HW agnostic manner Enable DM regulator and pwm Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-02-09board: ge: bx50v3: add i2c eeprom bootcount storageRobert Beckett
Add bootcount node, linking to i2c eeprom "bootcount" partitions for storage. Enable i2c eeprom bootcount backend storage. Enable bootcount command and use it for failbootcmd. Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-02-09board: ge: bx50v3, imx53ppd: use DM I2CRobert Beckett
Remove old (pre-DM) i2c setup code. Enable DM i2c. Convert common code to use DM rtc. Convert common code to read VPD from eeprom partition. Convert the generic i2c PMIC init code to use the new da9063 driver. mx53ppd only: Correct RTC compatible in device tree. Enable MXC DM i2c driver. Define CONFIG_SYS_MALLOC_F_LEN so that DM is available in pre-reloc. Make GPIO banks available during preloc, since initialisation is done in board_early_init_f(). Add gpio_request() calls to satisfy the DM_GPIO compatibility API. Remove unused power configuration. Signed-off-by: Robert Beckett <bob.beckett@collabora.com> Signed-off-by: Ian Ray <ian.ray@ge.com>
2020-02-06video: enable VIDEO_ANSI and all VIDEO_BBP optionsAnatolij Gustschin
This partially reverts changes by commit 2cc393f32fd9 ("video: make BPP and ANSI configs optional") since it caused issues with other boards (missing LCD console output on pinebook, x86 platform or sandbox). Enable all disabled options again and opt out of not supported color depth in board defconfigs. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Vagrant Cascadian <vagrant@debian.org>
2020-02-06configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-07board: ge: bx50v3: use imx wdtRobert Beckett
Enable DM imx WDT Enable SYSRESET_WATCHDOG to maintain WDT based reset ability Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-01-07board: ge: bx50v3: Enable DM for PCI and ethernetDenis Zalevskiy
DM for PCI pulls DM for ethernet that also needs other changes described below to build u-boot and keep existing functionality - ability to update MAC addresses of FEC ethernet adapter and I210 adapter connected to the Marvell switch. - fec_mxc driver with DM needs PHYLIB; - configuration items are moved from ge_bx50v3.h to ge_bx50v3_defconfig; - FEC is marked as eth0 because it is always present, so indices changed: I210 are still probed in the same order; - board_eth_init() was used by legacy ethernet, setup for enet iomux and pcie is moved to the board_late_init(); - pci_init() is called from the board_late_init() to initiate PCI bus probing, so I210 devices are propagated to the device tree; Signed-off-by: Denis Zalevskiy <denis.zalevskiy@ge.com> [Describe PHY reset in device tree] Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-01-07board: ge: bx50v3: Fix message output to video consoleIan Ray
Use vidconsole for output to the LCD, now that DM_VIDEO is used. Write white text on a black background, like before migrating to DM_VIDEO. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-01-07configs: bx50v3: Fix boot hang with videoIan Ray
Fixes commit: 0b09f7b15052bb419e318e38da453be46e5a13e5, which converted to DM_VIDEO, but requires more memory. [Inspired by 9002e735e71754a90adbb9676c0ffb1964dbc288] Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-01-07board: ge: bx50v3: sync devicetrees from LinuxRobert Beckett
Copy device trees from linux, keeping them as separate files for each board to ease future sync. Update board code to use generic bx50v3 dt initially, then select the specific dt based on board detection. Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2019-12-06video: make BPP and ANSI configs optionalAnatolij Gustschin
Many boards do not use all selected framebuffer depth configurations, for such boards there is some unused code in video and console uclass routines. Make depth specific code optional to avoid dead code and slightly reduce binary size. Also make ANSI code optional for the same reason. When i.e. using only VIDEO_BPP16 the code size shrinks (below values when using gcc-7.3.0): $ ./tools/buildman/buildman -b video-wip -sS wandboard ... 01: Merge git://git.denx.de/u-boot-sh 02: video: add guards around 16bpp/32bbp code 03: video: make BPP and ANSI configs optional arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0 Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Eugen Hristev <eugen.hristev@microchip.com> Tested-by: Patrice Chotard <patrice.chotard@st.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD is compiled when there is a SPI NOR flash using MTDMiquel Raynal
MTD must be enabled when there is a SPI NOR flash using the SPI_FLASH_MTD config entry. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-08watchdog: move WATCHDOG_TIMEOUT_MSECS to KconfigHeiko Schocher
move WATCHDOG_TIMEOUT_MSECS to Kconfig and fix all board defconfigs. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Martyn Welch <martyn.welch@collabora.com> Signed-off-by: Stefan Roese <sr@denx.de>
2019-08-23Convert CONFIG_FSL_USDHC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_FSL_USDHC Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-19pwm: imx: add Kconfig supportHeiko Schocher
add Kconfig support for this driver. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Martyn Welch <martyn.welch@collabora.co.uk>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-04-13imx6: ge_bx50v3: convert to DM_VIDEOAnatolij Gustschin
Enable DM_VIDEO in defconfig. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2019-04-13imx: move CONFIG_VIDEO_IPUV3 to defconfigsAnatolij Gustschin
2019-04-13board: ge: store version information in fdtIan Ray
Add board-specific FDT function to store U-Boot version in device tree. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: bx50v3: Enable CONFIG_DM_SPI, CONFIG_DM_SPI_FLASHIan Ray
Use SPI flash device model, and remove SPI pin configuration code since the pinctrl driver is used. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: bx50v3: Enable CONFIG_DM_GPIOIan Ray
Enable CONFIG_DM_GPIO as a pre-requisite for enabling CONFIG_DM_SPI. Add explicit gpio_requests. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: bx50v3: Enable CONFIG_DM_MMCIan Ray
Use MMC device model, and remove USDHC pin configuration code since the pinctrl driver is used. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: bx50v3: Enable CONFIG_DMIan Ray
Add simplified, generalised, bx50v3 device tree and enable CONFIG_DM. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-17board: ge: Move VPD EEPROM configuration to the defconfigDenis Zalevskiy
Use standard configuration logic to define EEPROM constants. Names are based on VPD_EEPROM_ prefix because EEPROM_ is already used by i2c_eeprom driver. Signed-off-by: Denis Zalevskiy <denis.zalevskiy@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-10-22Kconfig: Convert CONFIG_IMX_WATCHDOG to KconfigXiaoliang Yang
Move this option to Kconfig and tidy up the config file of eight boards which use it. Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
2018-08-17Migrate bootlimit to KconfigAlex Kiernan
Migrate boards which set bootlimit in the environment to Kconfig. We exclude gurnard_defconfig which includes a bootlimit=, but doesn't set CONFIG_BOOTCOUNT_LIMIT, so we'd fail to include a bootlimit setting if we migrated it. display5_defconfig and display5_factory_defconfig share a SYS_CONFIG_NAME, but only display5_defconfig enables CONFIG_BOOTCOUNT_LIMIT, so we fail to set bootlimit= in display5_factory_defconfig. This is okay because the display5_factory_defconfig doesn't need to have it set, as it is only meant to prepare the board in the factory. Environment changes for all modified configs as seen from buildman: boards.cfg is up to date. Nothing to do. Summary of 3 commits for 32 boards (8 threads, 1 job per thread) 01: Merge git://git.denx.de/u-boot-x86 arm: + draco etamin rastaban pxm2 display5 thuban rut 02: Add BOOTCOUNT_BOOTLIMIT to set reboot limit 03: Migrate bootlimit to Kconfig - display5_factory: bootlimit=3 Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-05-17board: ge: bx50v3: remove redundant targetsIan Ray
This replaces TARGET_GE_B{4,6,8}50V3 with common TARGET_GE_BX50V3. The boards are identified automatically at runtime. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
