path: root/configs/ge_b850v3_defconfig
2016-04-18bx50v3: Enable CONFIG_OF_LIBFDT in defconfigAkshay Bhat
As of commit 69e173eb57d1f4848f070c83456096ba5d2ba1b4, CONFIG_OF_LIBFDT needs to be selected in defconfig instead of board specific header file. Hence enable CONFIG_OF_LIBFDT in defconfig. Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
2016-03-09arm: imx: Add support for GE Bx50v3 boardsAkshay Bhat
Add support for GE B450v3, B650v3 and B850v3 boards. The boards are based on Advantech BA16 module which has a i.MX6D processor. The boards support: - FEC Ethernet - USB Ports - SDHC and MMC boot - SPI NOR - LVDS and HDMI display Basic information about the module: - Module manufacturer: Advantech - CPU: Freescale ARM Cortex-A9 i.MX6D - SPECS: Up to 2GB Onboard DDR3 Memory; Up to 16GB Onboard eMMC NAND Flash Supports OpenGL ES 2.0 and OpenVG 1.1 HDMI, 24-bit LVDS 1x UART, 2x I2C, 8x GPIO, 4x Host USB 2.0 port, 1x USB OTG port, 1x micro SD (SDHC),1x SDIO, 1x SATA II, 1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2 Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
