path: root/configs/ge_b450v3_defconfig
2016-10-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: common/Kconfig configs/dms-ba16_defconfig
2016-10-26config: Move CONFIG_DEFAULT_FDT_FILE to defconfigsJagan Teki
- Add DEFAULT_FDT_FILE kconfig entry - Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-07board: ge: bx50v3: disable unused features to improve size and boot speedAndrew Shadura
Disable unused FPGA, NFS, FAT and EFI support to reduce the bootloader size. Don't clear memory reserved for malloc to improve boot speed. Signed-off-by: Andrew Shadura <andrew.shadura@collabora.co.uk>
2016-06-07board: ge: bx50v3: make network support optional and disabled by defaultAndrew Shadura
The network support is only useful for development and shouldn't be enabled in production, so it has to be disabled in U-boot by default. Signed-off-by: Andrew Shadura <andrew.shadura@collabora.co.uk>
2016-06-07board: ge: bx50v3: make USB support optional and disabled by defaultAndrew Shadura
The USB support is only useful for development and shouldn't be enabled in production, so it has to be disabled in U-boot by default. Signed-off-by: Andrew Shadura <andrew.shadura@collabora.co.uk>
2016-04-18bx50v3: Enable CONFIG_OF_LIBFDT in defconfigAkshay Bhat
As of commit 69e173eb57d1f4848f070c83456096ba5d2ba1b4, CONFIG_OF_LIBFDT needs to be selected in defconfig instead of board specific header file. Hence enable CONFIG_OF_LIBFDT in defconfig. Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
2016-03-09arm: imx: Add support for GE Bx50v3 boardsAkshay Bhat
Add support for GE B450v3, B650v3 and B850v3 boards. The boards are based on Advantech BA16 module which has a i.MX6D processor. The boards support: - FEC Ethernet - USB Ports - SDHC and MMC boot - SPI NOR - LVDS and HDMI display Basic information about the module: - Module manufacturer: Advantech - CPU: Freescale ARM Cortex-A9 i.MX6D - SPECS: Up to 2GB Onboard DDR3 Memory; Up to 16GB Onboard eMMC NAND Flash Supports OpenGL ES 2.0 and OpenVG 1.1 HDMI, 24-bit LVDS 1x UART, 2x I2C, 8x GPIO, 4x Host USB 2.0 port, 1x USB OTG port, 1x micro SD (SDHC),1x SDIO, 1x SATA II, 1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2 Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
