path: root/configs/gardena-smart-gateway-mt7688_defconfig
2020-04-27mips: mtmips: Increase CONFIG_SPL_SYS_MALLOC_F_LENStefan Roese
Since SPL now uses malloc to allocate the buffer for the compressed image before decompression to the destination address, we need to configure a big enough malloc space in SPL. 256k seems to be big enough even for the GARDENA board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mtmips: enable SPL for all boardsWeijie Gao
This patch enables SPL for all mtmips boards. And also remove defconfig files which are intend to build ram bootable u-boot files. SPL_DM and OF_CONTROL are enabled for both boards. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mtmips: rewrite lowlevel codes of mt7628Weijie Gao
This patch rewrites the mtmips architecture with the following changes: 1. Move MT7628 soc parts into a subfolder. 2. Lock parts of D-Cache as temporary stack. 3. Reimplement DDR initialization in C language. 4. Reimplement DDR calibration in a clear logic. 5. Add full support for auto size detection for DDR1 and DDR2. 6. Use accurate CPU clock depending on the input xtal frequency for timer and delay functions. Note: print_cpuinfo() has incompatible parts with MT7620 so it's moved into mt7628 subfolder. Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mtmips: make use of sysreset-resetctrl for mt7628 socWeijie Gao
This patch replaces sysreset-syscon with sysreset-resetctrl for mt7628 soc. Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27configs: enable CONFIG_RESTORE_EXCEPTION_VECTOR_BASE for all mtmips boardsWeijie Gao
This patch enables CONFIG_RESTORE_EXCEPTION_VECTOR_BASE for all mtmips boards. Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-02-28configs: Resync with savedefconfigTom Rini
2020-02-06configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_MTD -> CONFIG_DM_MTDMiquel Raynal
CONFIG_MTD must be reserved for the MTD core. Like any other subsystem, prefix the symbol by DM when it comes to DM support. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Add Kconfig files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-12defconfigs: Migrate CONFIG_SYS_REDUNDAND_ENVIRONMENTTom Rini
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-25configs: mtmips: remove configs which are selected in Kconfig or uselessWeijie Gao
Some configs are selected in Kconfig and is no longer needed in the defconfig files. Some configs (power domain, ram) are never used. Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-07-11configs: Rename CONFIG_IMAGE_FORMAT_LEGACY to CONFIG_LEGACY_IMAGE_FORMATTom Rini
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of cmd/ switch to using CONFIG_IS_ENABLED() to test what is set. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-24mips: mt76xx: gardena-smart-gateway: Enable CONFIG_USE_PREBOOTStefan Roese
Enable CONFIG_USE_PREBOOT on for the gardena mt7688 platforms, so that this feature can be used here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-05-24mips: mt7688: gardena-smart-gateway-mt7688: Enable CMD_WDTStefan Roese
This patch enables the "wdt" command, which is quite useful for watchdog testing. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-05-03mips: rename mach-mt7620 to mach-mtmipsWeijie Gao
Currently mach-mt7620 contains only support for mt7628. To avoid confusion, rename mach-mt7620 to mach-mtmips, which means MediaTek MIPS platforms. MT7620 and MT7628 should be distinguished by SOC_MT7620 and SOC_MT7628 because they do not share the same lowlevel codes. Dependencies of four drivers are changed to SOC_MT7628 as these drivers are only used by MT7628. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2019-01-16mips: mt7688: gardena-smart-gateway: Update mtdparts/mtdids for Kernel 4.19Stefan Roese
With the new SPI NOR framework in v4.19, we need to adapt the MTD parts so that the kernel cmdline parameter "mtdparts=" uses the correct naming for the devices. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-12-19mips: mt76xx: linkit/gardena: Don't use CONFIG_OF_EMBEDStefan Roese
Building with CONFIG_OF_EMBED generates build warnings, as it should only be used for debugging purposes. So let's move all MT7688 targets to CONFIG_OF_SEPARATE instead with this patch. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-11-30mips: mt76xx: gardena-smart-gateway: Misc updates to defconfigStefan Roese
The following changes are made: - Add default bootcmd which can be used for initial start-up - Setup necessary MTD parts for Linux compatibility Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-11-18mips: mt76xx: gardena-smart-gateway: Misc updates to dts/config/defconfigStefan Roese
These misc updates include the following changes: - Change baudrate from 57600 to 115200 - Enable MIPS_BOOT_CMDLINE_LEGACY - Enable FIT support - Enable ethernet support - Enable SPI NOR and NAND support - Change MTD_UBI_BEB_LIMIT to 22 - Enable MTD Support - Enable GPIO support - Enable watchdog support - Enable bootcounter support - Enable version variable - Change max image size from 0x80000 to 0xa0000 - Change SYS_MALLOC_LEN to 16MiB (because of UBI/UBIFS) Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-23mips: Add Gardena Smart-Gateway board supportStefan Roese
The Gardena Smart-Gateway boards have a MT7688 SoC with 128 MiB of RAM and 8 MiB of flash (SPI NOR) and additional 128MiB SPI NAND storage. This patch also includes 2 targets. One is the target that can be programmed into the SPI NOR flash and a 2nd target "xxx-ram" is added to support loading and booting via an already running U-Boot version. This allows easy development and testing without the need to flash the image each time. Signed-off-by: Stefan Roese <sr@denx.de> [fixed and regenerated defconfig files] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
