path: root/configs/gardena-smart-gateway-at91sam_defconfig
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28Convert CONFIG_SPL_NAND_BASE et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SPL_NAND_BASE CONFIG_SPL_NAND_IDENT Signed-off-by: Adam Ford <aford173@gmail.com>
2020-07-28Convert CONFIG_SPL_NAND_DRIVERS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SPL_NAND_DRIVERS CONFIG_SPL_NAND_ECC CONFIG_SPL_NAND_SIMPLE Signed-off-by: Adam Ford <aford173@gmail.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-07Merge tag 'u-boot-atmel-2020.10-a' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-atmel First set of u-boot-atmel features for 2020.10 cycle
2020-07-06configs: Resync with savedefconfigTom Rini
2020-06-18configs: atmel: cleanup CONFIG_SPL_SEPARATE_BSSGregory CLEMENT
Now that CONFIG_SPL_SEPARATE_BSS is selected for all the AT91 based boards, cleanups the defconfigs by removing it. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2020-06-04configs: Resync with savedefconfigTom Rini
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-21configs: Resync with savedefconfigTom Rini
2019-11-12defconfigs: Migrate CONFIG_SYS_REDUNDAND_ENVIRONMENTTom Rini
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-09-30arm: at91: gardena-smart-gateway-at91sam: Enable CONFIG_SYS_NAND_USE_FLASH_BBTStefan Roese
This patch enables the BBT in NAND on the AT91SAM based GARDENA smart Gateway. This is especially important, since the Linux driver also enables this option and uses the BBT table pages. Without setting this option, U-Boot will try to re-use these pages again (e.g. UBI). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Tom Rini <trini@konsulko.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25mtd: nand: raw: Move CONFIG_SYS_NAND_USE_FLASH_BBT to KconfigStefan Roese
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs, headers and whitelist. Please note that this symbol already was used in Kconfig (imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was not available in Kconfig. This changes now with this patch and all boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what I also need on my GARDENA AT91SAM based board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Miquel Raynal <miquel.raynal@bootlin.com> Cc: Gregory CLEMENT <gregory.clement@bootlin.com> [trini: Rework such that the configs are unchanged to start with] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-25configs: Resync with savedefconfigTom Rini
2019-08-14configs: Resync with savedefconfigTom Rini
2019-07-09at91, omap2plus: configs: migrate CONFIG_ENV_ to defconfigsMarkus Klotzbuecher
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be able to use CONFIG_ENV_UBI_* on these architectures. As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE, ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to KConfig. This migration was run using an extended moveconfig.py which evaluates expressions such as "(512 << 10)". See patch ("moveconfig: expand simple expressions"). All modified boards were built with SOURCE_DATE_EPOCH=0 before and after the change and successfully confirmed that the identical binary is generated (the only exception was igep00x0, which does not define CONFIG_ENV_IS_IN_UBI in the original board header. Once that is defined, the test passes too). hs: rebased patch to: 68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT" Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com> Cc: Heiko Schocher <hs@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Tom Rini <trini@konsulko.com>
2019-05-15arm: at91: gardena-smart-gateway-at91sam: Enable CMD_WDTStefan Roese
This patch enables the "wdt" command, which is quite useful for watchdog testing. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com>
2019-04-26watchdog: at91sam9_wdt: Remove now superfluous wdt start and resetStefan Roese
With the new generic function, the scattered other functions are now removed to be replaced by the generic one. The new version also enables the configuration of the watchdog timeout via the DT "timeout-sec" property (if enabled via CONFIG_OF_CONTROL). The watchdog servicing is enabled via CONFIG_WATCHDOG. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com>
2019-04-09arm: at91: Add gardena-gateway-at91sam supportStefan Roese
The GARDENA smart Gateway boards are equipped with an Atmel / Microchip AT91SAM9G25 SoC and with 128 MiB of RAM and 256 MiB of NAND storage. This patch adds support for this board including SPL support. Therefore the AT91Boostrap is not needed on this platform any more. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas@biessmann.org> Cc: Eugen Hristev <eugen.hristev@microchip.com> Reviewed-by: Heiko Schocher <hs@denx.de>
