path: root/configs/ga10h_v1_1_defconfig
2015-08-05sunxi: usb: USB_MUSB_SUNXI move to musb-new KconfigPaul Kocialkowski
Now that the musb-new driver has a Kconfig, we can move Kconfig options to enable controllers to it, so that it's easier in e.g. menuconfig. In addition, this allows declaring support for USB_MUSB_HOST/GADGET in defconfigs instead of the USB_MUSB_SUNXI controller, that will get selected automatically when needed. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-07-25sunxi: ga10h: Enable both otg and regular usb host controllersHans de Goede
This allows using devices plugged into both ports of the tablet. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-06-05sunxi: Add a proper dts file for the ga10h a33 based tabletHans de Goede
Add and use a proper dts for the ga10h a33 based tablet, as submitted upstream. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-19sunxi: Add ga10h v1.1 defconfigHans de Goede
The ga10h is an 10" tablet with an A33 or A23 soc, 1G RAM, 8G or 16G nand, sdio wifi, 2 micro usb ports, 1 otg and 1 host and 1 micro sd slot. This commit adds a defconfig for the v1.1 pcb with an a33 soc. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
