This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after
its Kconfig conversion it has ended up missing on some recently
added boards.
Simply select it for ARCH_SUNXI, so that we get it on all
sunxi boards for both a consistent user experience and simpler
defconfig files.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost
all our defconfigs. This also fixes it missing from some recently
added defconfigs.
This commit also modifies our ft_board_setup() to not cause warnings
when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always
build it.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Select SYS_NS16550 from Kconfig instead of setting it in all our
defconfig files.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
On A23 / A33 boards aldo1 is used for VCC-IO and should be 3.0V, make this
the default.
Note that this does not cause any functional changes since all sun8i
board defconfig-s already contained: CONFIG_AXP_ALDO1_VOLT=3000 .
On boards with axp221/223 pmic-s we already allow configuring most
voltages. Make the Kconfig options for these also apply to boards with
axp152 / axp209 pmic-s and extend them to configure all voltages.
The Kconfig defaults are chosen so that this commit does not introduce any
functional changes.
Several files are out of order. This means that when the moveconfig tool
moves CONFIG options to Kconfig it generates a large diff. To avoid this,
reorder the files first.
Now that the musb-new driver has a Kconfig, we can move Kconfig options to
enable controllers to it, so that it's easier in e.g. menuconfig.
In addition, this allows declaring support for USB_MUSB_HOST/GADGET in
defconfigs instead of the USB_MUSB_SUNXI controller, that will get selected
automatically when needed.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
This allows using devices plugged into both ports of the tablet.
With certain features being convert to DM now we want sunxi to default
to having DM enabled for ETH/SERIAL and USB in some cases.
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
[hdegoede@redhat.com: Also select CONFIG_USB for all sunxi builds]
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
Select CONFIG_CMD_NET and CONFIG_CMD_SETEXPR by default rather then
needing to have this in every sunxi defconfig file.
This also fixes the Merrii_A80_Optimus defconfig no longer building.
Cc: Maxin B. John <maxin.john@enea.com>
Reported-by: Maxin B. John <maxin.john@enea.com>
Add and use a proper dts for the ga10h a33 based tablet, as
submitted upstream.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
The ga10h is an 10" tablet with an A33 or A23 soc, 1G RAM, 8G or 16G nand,
sdio wifi, 2 micro usb ports, 1 otg and 1 host and 1 micro sd slot.
This commit adds a defconfig for the v1.1 pcb with an a33 soc.
