The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
CONFIG_BOARD_EARLY_INIT_F
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Some boards' defconfigs are disordered. Reorder them.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
