path: root/configs/firefly-rk3399_defconfig
2018-04-25rockchip: defconfig: remove CONFIG_SYS_NS16550Kever Yang
We have enable NS16550 in Kconfig, do not need enable at defconfig Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-03rockchip: firefly-rk3399: enable SPL_ATF_NO_PLATFORM_PARAMPhilipp Tomsich
The Rockchip-released ATF for the Firefly apparently (i.e. Kever reported this) does not tolerate a FDT being passed as the platform parameter and will run into a hard stop. To work around this limitation in the ATF parameter handling, we enable SPL_ATF_NO_PLATFORM_PARAM (which will force passing NULL for the platform parameters). Note that this only affects this platform, as the ATF releases for the RK3368 and RK3399 have always either ignored the platform parameter (i.e. before the FDT-based parameters were supported) or support receiving a pointer to a FDT. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2017-12-18rockchip: firefly-rk3399: add FIT for rk3399Kever Yang
Enable SPL_FIT_GENERATOR with path for it. With this patch you can get u-boot.itb for rk3399-firefly with: > make u-boot.itb Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Mark Kettenis <kettenis@openbsd.org> Tested-by: Mark Kettenis <kettenis@openbsd.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-18rockchip: update ROCKCHIP_SPL_RESERVE_IRAM to 0Kever Yang
Only rk3399 atf need ROCKCHIP_SPL_RESERVE_IRAM. This commit updates its default setting to 0 so that other SoCs do not need to define it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-26rockchip: defconfig: firefly-rk3399: sync up with SPL changes for ATFPhilipp Tomsich
This tracks the SPL changes for ATF for the Firefly: * renames ATF_SUPPORT to ATF * drops CONFIG_SPL_ATF_TEXT_BASE Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-07rockchip: remove SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR from defconfigKever Yang
Use default value 0x4000 for SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR instead of define a new one. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-05rockchip: firefly-rk3399: enable ATF and dwmmcKever Yang
enable the ATF option and SDCard in defconfig. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: firefly-rk3399: enable dwmmc driver for the boardKever Yang
Enable mmc_dw_rockchip driver, disable CONFIG_SPL_OF_PLATDATA first for some dependence patches still not merged. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Tested-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07defconfig: firefly-rk3399: fix pinctrl config optionHeiko Stübner
The option is named PINCTRL_ROCKCHIP_RK3399 not ROCKCHIP_RK3399_PINCTRL. Set the correct option. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2017-05-10power: rk808: rename to rk8xxJacob Chen
Since this driver can be used for rk8xx series pmic, let's rename rk808 to rk8xx, to make it clear. Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./` Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-05-10rockchip: add defconfig for firefly-rk3399Kever Yang
The file is from evb-rk3399_defconfig with changes: - use rk3399-firefly dtb - re-order by make savedefconfig Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
