path: root/configs/firefly-rk3399_defconfig
2017-05-10power: rk808: rename to rk8xxJacob Chen
Since this driver can be used for rk8xx series pmic, let's rename rk808 to rk8xx, to make it clear. Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./` Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-05-10rockchip: add defconfig for firefly-rk3399Kever Yang
The file is from evb-rk3399_defconfig with changes: - use rk3399-firefly dtb - re-order by make savedefconfig Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
