After moving some USB gadget configs (USB_FUNCTIONS_*) to Kconfig it
turned out that following *_defconfig entries for RockChip are not
needed.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
CONFIG_ROCKCHIP_USB2_PHY
this patch enable rockusb support on rk3288 based device.
Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com>
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Fastboot need a bunch of options to be operating properly, such as the
g_dnl gadget, the fastboot command, and some options that make sense. Since
fastboot is now part of Kconfig, make sure we have them right.
That will also reduce the boilerplate in the defconfigs.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
The choice of "USB keyboard polling" cannot be optional as without
one mechanism being set, it just doesn't work. Set the default one
to CONFIG_SYS_USB_EVENT_POLL.
Fixes: ecad7051 ("configs: Migrate all of the existing USB symbols, except fastboot")
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's
not strictly part of fastboot.
- Add some defaults for the fastboot buffer location and size
- Migrate all options listed in cmd/fastboot/Kconfig
- Cleanup the README
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
The back-to-bootrom option is rather unfortunately named
CONFIG_ROCKCHIP_SPL_BACK_TO_BOOTROM
instead of
CONFIG_SPL_ROCKCHIP_BACK_TO_BOOTROM
To make is selectable through CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BOOTROM),
we need to rename it. At the same time, we introduce a TPL_ variant of
the option to give us finer-grained control over when it should be used.
This change is motivated by our RK3368 boot process, which returns to
the boot ROM only from the TPL stage, but not from the SPL stage.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[added fix-up for evb-rk3229_defconfig and phycore-rk3288_defconfig:]
[fixed inverted CONFIG_IS_ENABLED test for rk3288:]
include/configs/rock.h: undef
Add four macros of CONFIG_USB_KEYBOARD,CONFIG_DM_KEYBOARD,etc in the
firefly-rk3288_defconfig,can support usb keyboard device when these four
macros are enabled.
Signed-off-by: Leo Wen <leo.wen@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
This change migrates the USB_DWC2 configuration item to Kconfig
and runs moveconfig to adjust header files and defconfig.
Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com>
Split off into a separate patch:
Ran moveconfig to migrate other boards:
1. add Kconfig for rockchip video driver, so that video port can be
selected as needed.
2. move VIDEO_ROCKCHIP option to new Kconfig for concision.
Signed-off-by: Eric Gao <eric.gao@rock-chips.com>
Drop indenting in Kconfig:
This originally started out as
"pinctrl: Kconfig: reorder to keep Rockchip options together"
and tried to keep the Rockchip-related config options together.
However, we now rewrite all chip-specific driver selections to start
with CONFIG_PINCTRL_ (with the inadvertent changes to related
Makefiles) and sort those alphabetically. And as this already means
touching most of the file, we also reformat the help text to not exceed
80 characters (but make full use of those 80 characters).
RK3288 using the dwc2 USB host controller, enable it and other usb host
funtion like storage and ethernet.
We should remove config_spl_of_platdata to build u-boot-spl-dtb.bin rather than u-boot-spl-nodtb.bin
since we use spl_back_to_brom.
I miss it because i forget to clean build-dir..
Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
This commit enables ethernet MAC address randomization on the
firefly-rk3288. It removes the error at startup 'ethernet@ff290000
address not set'.
Signed-off-by: Romain Perier <romain.perier@collabora.com>
Keep it same with other boards otherwise i have to write special script for it..
Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com>
We convert CONFIG_PARTITION_UUIDS to Kconfig first. But in order to cleanly
update all of the config files we must also update CMD_PART and CMD_GPT to also
be in Kconfig in order to avoid complex logic elsewhere to update all of the
config files.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Enable the various configuration option required to get the ethernet
interface up and running on Radxa Rock2 and Firefly.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
This commit was created as follows:
[1] Rename the option with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g'
[2] create the entry for MMC_DW in drivers/mmc/Kconfig
(the prompt and help were copied from Linux)
[3] run "tools/moveconfig.py -y MMC_DW"
[4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry
[5] Clean-up doc/README.socfpga by hand
I am trying to make all DesignWare-based driver options prefixed
with CONFIG_MMC_DW_.
This commit was generated as follows:
find . -name .git -prune -o -type f -print | \
xargs sed -i -e 's/ROCKCHIP_DWMMC/MMC_DW_ROCKCHIP/g'
CONFIG_CONSOLE_SCROLL_LINES
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
Reviewed-by: Jagan Teki <jteki@openedev.com>
[trini: Re-migrate, update common/console.c logic]
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
in certain architectures. Migrate all config files.
The rk3288 pinctrl is very specific to this soc, so should
not hog the generic rockchip naming.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
As an experiment, move this board over to use of-platdata. This means that
its SPL configuration will come from C structures generated at build-time
from the device tree, instead of coming from the device tree at run-time.
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
While we consider whether to drop use of DT in SPL, remove some unwanted
properties. This reduces SPL size by about 250 bytes.
The current reset API implements a method to reset the entire system.
In the near future, I'd like to introduce code that implements the device
tree reset bindings; i.e. the equivalent of the Linux kernel's reset API.
This controls resets to individual HW blocks or external chips with reset
signals. It doesn't make sense to merge the two APIs into one since they
have different semantic purposes. Resolve the naming conflict by renaming
the existing reset API to sysreset instead, so the new reset API can be
called just reset.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
