CONFIG_SPL_STACK
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SPL_BSS_MAX_SIZE
CONFIG_SPL_MAX_FOOTPRINT
Note that the da850evm platforms were violating the "only use one" rule
here, and so now hard-code their BSS limit.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_{SPL,TPL}_SIZE_LIMIT are defined as hex (SPL_SIZE_LIMIT was
converted in b51882d0 ("spl: Convert CONFIG_SPL_SIZE_LIMIT to hex"), but
there are still places that reference integer values. Change those to hex
as well. Also, update the Makefile to check for 0x0 instead of 0.
This also fixes the following build error when CONFIG_SPL_SIZE_LIMIT
is set by menuconfig to 0x0:
spl/u-boot-spl.bin exceeds file size limit:
limit: 0 bytes
actual: 0x80f0 bytes
excess: 0x80f0 bytes
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
RK3288, RK3399 are now support cpu-info, so enable
DISPLAY_CPUINFO by default.
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- Clean vid/pid in Kconfig and add fastboot for rk3399
- add 'u-boot, spl-fifo-mode' for mmc
- Use FIT generator for rk3229 optee and rk3368 ATF
- fan53555: add support for Silergy SYR82X and SYR83X
Select CONFIG_FASTBOOT_FLASH, CONFIG_FASTBOOT_FLASH_MMC_DEV
for rockchip SoC plaforms in fastboot Kconfig file instead
of defined it in board defconfig.
This eventually drop the explicit configs defined in
supporting board defconfig files.
Tested-by: Levin Du <djw@t-chip.com.cn>
Rockchip support differnet or common gadget product number
between Rockchip SoCs like,
0x310a - rk3036
0x320a - rk3229, rk3288
0x330a - rk3328
So, select them on Kconfig based on platform specific
config defined.
Gadget vendor number, 0x2207 is common across all platfroms
supported in Rockchip SoC.
So, select the same number globally, if ARCH_ROCKCHIP.
This eventually drop the explicit configs defined in supported
Select the gadget manufacturer as 'Rockchip' for
all rockchip platform SoC's.
This eventually drop the explicit defined added
on supported board defconfig files.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
- Add support for rockchip pmic rk805,rk809, rk816, rk817
- Add rk3399 board Leez support
- Fix bug in rk3328 ram driver
- Adapt SPL to support ATF bl31 with entry at 0x40000
- Fix the u8 type comparision with '-1'.
- Fix checkpatch warning for multi blank line and review signature.
This patch enable TPL support for firefly-rk3288 board, which works ths
same way with other RK3288 board like Tinker, evb.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
This affects RK3036, RK322X and RK3288 - the defconfig changes done by
moveconfig.py for the veyrons were left out on purpose because they dont
have an OTG port, and will get their config updated in the next commit.
Signed-off-by: Urja Rannikko <urjaman@gmail.com>
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
There is no difference in rk3288 board use for SYS_MALLOC_F_LEN,
so we can use default value.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_MODE
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Completely move CONFIG_SPI_FLASH from remaining board header files to
defconfigs
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
If we used the pinctrl-rockchip driver, these config is not needed,
so remove them.
Signed-off-by: David Wu <david.wu@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Currently the fdtfile environment variable is set to
CONFIG_DEFAULT_DEVICE_TREE which is іnternally used as U-Boot devicetree
source. The OS can use a different filename and Kconfig gives us the
ability to select a default devicetree via CONFIG_DEFAULT_FDT_FILE.
This also gives user configuring U-Boot via menuconfig the behaviour
someone would expect.
Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Tested-By: Vagrant Cascadian <vagrant@debian.org>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Convert USB fastboot code to use shared fastboot protocol.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
We have enable NS16550 in Kconfig, do not need enable at defconfig
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
