path: root/configs/firefly-px30_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-30rockchip: px30: remove CONFIG_OPTEE supportKever Yang
Rockchip use CONFIG_SPL_OPTEE for OPTEE support, which is load and run before U-Boot, but not use CONFIG_OPTEE which is after U-Boot. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-27rockchip: px30-firefly add standalone dtsKever Yang
Firefly Core-PX30-JD4 use UART2M1 while PX30 evb using UART2M0, the U-Boot proper will use the dts setting to do the IOMUX init, and a separate dts is needed for px30-firefly. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-12-27rockchip: firefly-px30: Fix the MACRO for CONFIG_DEBUG_UART2_CHANNELKever Yang
The Macro has update without update the defconfig, update the defconfig to make Mcaro correct. Fixes: ec4fafdf1f ("rockchip: px30: Rename CONFIG_DEBUG_UART2_CHANNEL to...") Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-12-06rockchip: config: add support for firefly-px30 boardKever Yang
This is a core board named Core-PX30-JD4 with a mainboard from Firefly, name it as firefly-px30 for now. This board can re-use the dts of PX30, the only difference is the UART IO, the firefly use UART2 M1 while evb use UART2 M0. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
