path: root/configs/evb-rk3399_defconfig
2017-05-10rockchip: defconfigs: Add mipi dsi support for rk3399 evb boardEric Gao
Add mipi dsi configs for rk3399 evb board Signed-off-by: Eric Gao <eric.gao@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-10power: rk808: rename to rk8xxJacob Chen
Since this driver can be used for rk8xx series pmic, let's rename rk808 to rk8xx, to make it clear. Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./` Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-05-10rockchip: dts: evb-rk3399: add gmac supportKever Yang
Enable gmac for evb-rk3399. Change-Id: I85e35667e08e22e38577e63eb0e65731fc9c69b6 Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2017-04-27pinctrl: Kconfig: sort pinctrl config options to prevent future clutterPhilipp Tomsich
This originally started out as "pinctrl: Kconfig: reorder to keep Rockchip options together" and tried to keep the Rockchip-related config options together. However, we now rewrite all chip-specific driver selections to start with CONFIG_PINCTRL_ (with the inadvertent changes to related Makefiles) and sort those alphabetically. And as this already means touching most of the file, we also reformat the help text to not exceed 80 characters (but make full use of those 80 characters). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-15rockchip: pmic: Enable RK808 for rk3399 evberic.gao@rock-chips.com
For using mipi display, we need to enable lcd3v3 which supplied by rk808,so enable rk808 first. Signed-off-by: Eric Gao <eric.gao@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-15rockchip: i2c: Enable i2c for rk3399eric.gao@rock-chips.com
To enable mipi display, we need to enable pmic rk808 first for lcd3v3 power,which use i2c0 to communicate with soc. So enable i2c0. Signed-off-by: Eric Gao <eric.gao@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-04defconfig: puma-rk3399: add defconfig for the RK3399-Q7 (Puma)Philipp Tomsich
This commit adds the baseline defconfig for the RK3399-Q7 (Puma) SoM (under the name 'puma-rk3399_defconfig') featuring the Rockchip RK3399 in a Qseven compatible module. This subsumes the following changes: * defconfig: rk3399: migrate CONFIG_SPL_LIBCOMMON_SUPPORT/CONFIG_SPL_LIBGENERIC_SUPPORT * defconfig: rk3399-puma: add CONFIG_MMC_DW_ROCKCHIP * defconfig: rk3399-puma: disable CONFIG_SPL_OF_PLATDATA * defconfig: rk3399-puma: don't USE_TINY_PRINTF * defconfig: rk3399-puma: set up CONFIG_SYS_BOARD for the RK3399-Q7 * defconfig: rk3399-puma: enable the multi-image loading via CONFIG_SPL_FIT * defconfig: rk3399-puma: SPL should be able to boot from MMC/SD card * defconfig: rk3399-puma: enable GMAC support * defconfig: rk3399-puma: enable support for SPI and Winbond SPI flash * defconfig: rk3399-puma: enable SPI as a boot-source in SPL * defconfig: rk3399-puma: disallow non-FIT images from being loaded * defconfig: rk3399-puma: rename to puma-rk3399 * rockchip: config: rk3399: update defconfigs and rk3399_common For the RK3399-Q7, we want a default boot-order of SPI -> MMC -> uSD. This both follows how the BootROM probes devices and is a sane default for customers in device-personalisation (e.g. it allows for quick and easy factory programming of unpersonalised devices using an SD card) and field usage (with customer devices expected to have their firmware either in SPI or MMC). However, when probing multiple interfaces (according to the result from the board_boot_order function), we need to ensure that only valid FIT images are considered and disable the fallback to assuming that a raw (binary-only) U-Boot image is loaded (to avoid hangs/crashes from jumping to random content loaded from devices that are probed, but don't contain valid image content). By disabling the SPL_RAW_IMAGE_SUPPORT and SPL_LEGACY_IMAGE_SUPPORT options, we ensure that raw images (indistinguishable from random data) are not considered for booting. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org> Drop CONFIG_DEBUG_UART_BOARD_INIT: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-16rockchip: config: rk3399: enable SPL config for evb-rk3399Kever Yang
Enable all the CONFIGs which need by SPL. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org> Added rockchip tag: Drop CONFIG_ROCKCHIP_DWMMC for now due to build error: Move changes to arch/arm/mach-rockchip/Kconfig to this patch: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-31mmc: rockchip: rename CONFIG_ROCKCHIP_SDHCI to CONFIG_MMC_SDHCI_ROCKCHIPMasahiro Yamada
Make the naming scheme consistent; all SDHCI-base drivers prefixed with CONFIG_MMC_SDHCI_. While we are here, add "depends on ARCH_ROCKCHIP". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-11rockchip: evb-rk3339: Enable DHCPSimon Glass
This is the only RK3399 device without DHCP. Enable it so that we can use a common BOOT_TARGET_DEVICES setting. It is likely useful to be able to use USB networking, at least. Full networking can be enabled when a suitable platform needs it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-11mmc: move CONFIG_DWMMC to Kconfig, renaming to CONFIG_MMC_DWMasahiro Yamada
This commit was created as follows: [1] Rename the option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g' [2] create the entry for MMC_DW in drivers/mmc/Kconfig (the prompt and help were copied from Linux) [3] run "tools/moveconfig.py -y MMC_DW" [4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry [5] Clean-up doc/README.socfpga by hand Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-11mmc: rename CONFIG_ROCKCHIP_DWMMC to CONFIG_MMC_DW_ROCKCHIPMasahiro Yamada
I am trying to make all DesignWare-based driver options prefixed with CONFIG_MMC_DW_. This commit was generated as follows: find . -name .git -prune -o -type f -print | \ xargs sed -i -e 's/ROCKCHIP_DWMMC/MMC_DW_ROCKCHIP/g' Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-11-25config: evb-rk3399: enable PWM_ROCKCHIPKever Yang
PWM_ROCKCHIP need to enable for PWM regulator, this config is missing during rebase and new patch set in previous submission. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01config: evb-rk3399: enable pwm regulatorKever Yang
Enable the pwm regulator for evb-rk3399. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-22config: evb-rk3399: enable fixed regulatorKever Yang
This patch enable fixed regulator driver for rk3399 evb. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-22config: rk3399: add usb related configsMengDongyang
This patch to enable configs for usb module - xhci - ehci - usb storage - usb net Signed-off-by: MengDongyang <daniel.meng@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Squashed in patch to move to Kconfig: https://patchwork.ozlabs.org/patch/672543/ Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-22config: evb-rk3399: enable pinctrl driverKever Yang
This patch enable rk3399 pinctrl driver and gpio driver which is sub-node of pinctrl. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-05config: rk3399: enable dwmmc controllerKever Yang
Enable the rockchip dwmmc driver for rk3399 and its evb. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25config: add config file for evb-rk3399Kever Yang
This patch add basic config option for evb-rk3399 board. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
