path: root/configs/evb-rk3328_defconfig
2019-06-26rockchip: Kconfig: enable SPL support for rk3328Kever Yang
Enable SPL support and some related option in Kconfig. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> [cherry picked from https://github.com/rockchip-linux/u-boot/commit/430b01462bf3f24aaf7920ae2587a6943c39ab5d with minor modifications] Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-02-07configs: Move CONFIG_SPI_FLASH into defconfigsVignesh R
Completely move CONFIG_SPI_FLASH from remaining board header files to defconfigs Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-07configs: evb-rk3328: Enable CONFIG_USB_DWC3Jean-Jacques Hiblot
This is now required because the PHY operations used by xhci-dwc3 are part of the dwc3 core. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-07-21rockchip: utilize CONFIG_DEFAULT_FDT_FILEKlaus Goger
Currently the fdtfile environment variable is set to CONFIG_DEFAULT_DEVICE_TREE which is Ñ–nternally used as U-Boot devicetree source. The OS can use a different filename and Kconfig gives us the ability to select a default devicetree via CONFIG_DEFAULT_FDT_FILE. This also gives user configuring U-Boot via menuconfig the behaviour someone would expect. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Tested-By: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-05-30usb: fastboot: Convert USB f_fastboot to shared fastbootAlex Kiernan
Convert USB fastboot code to use shared fastboot protocol. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-25rockchip: defconfig: remove CONFIG_SYS_NS16550Kever Yang
We have enable NS16550 in Kconfig, do not need enable at defconfig Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-28rockchip: configs: Enable GMAC configs for evb-rk3328David Wu
Enable GMAC configs for evb-rk3328 Signed-off-by: David Wu <david.wu@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-01configs: rk3328: add support for pmic rk8xx and regulator and i2c driverElaine Zhang
Add defconfig for rk8xx and regulator and i2c controller. Signed-off-by: Elaine Zhang <zhangqing@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25configs: Resync with savedefconfigTom Rini
2017-07-11rockchip: dts: rk3328: add fixed regulator node for xhciMeng Dongyang
The driver changes gpio to fixed regulator to control vbus, so add fixed regulator node in DTS for xhci driver. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07configs: rk3328: config xhci controllerMeng Dongyang
Add config of max root ports and add config to enable xhci controller. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07configs: rk3328: add support for usb and config ehci and ohci driverMeng Dongyang
Add defconfig for usb and ehci and ohci controller, config maximal number of ports of the root hub for ohci driver. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-27pinctrl: Kconfig: sort pinctrl config options to prevent future clutterPhilipp Tomsich
This originally started out as "pinctrl: Kconfig: reorder to keep Rockchip options together" and tried to keep the Rockchip-related config options together. However, we now rewrite all chip-specific driver selections to start with CONFIG_PINCTRL_ (with the inadvertent changes to related Makefiles) and sort those alphabetically. And as this already means touching most of the file, we also reformat the help text to not exceed 80 characters (but make full use of those 80 characters). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-03-16rockchip: rk3328: add defconfig for evb-rk3328Kever Yang
Enable board config for evb-rk3328. SDcard and eMMC boot is OK in this initial version, USB and EMAC function is not available now, will comes later. Signed-off-by: William Zhang <william.zhang@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
