Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
This commit was created as follows:
[1] Rename the option with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g'
[2] create the entry for MMC_DW in drivers/mmc/Kconfig
(the prompt and help were copied from Linux)
[3] run "tools/moveconfig.py -y MMC_DW"
[4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry
[5] Clean-up doc/README.socfpga by hand
I am trying to make all DesignWare-based driver options prefixed
with CONFIG_MMC_DW_.
This commit was generated as follows:
find . -name .git -prune -o -type f -print | \
xargs sed -i -e 's/ROCKCHIP_DWMMC/MMC_DW_ROCKCHIP/g'
Generated by "tools/moveconfig -s".
This will make config moves easier.
Enable ROCKCHIP_SPL_BACK_TO_BROM and disable CONFIG_SPL_MMC_SUPPORT
to save memory in order to enable add source code for dram capacity
auto-detect.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
Reviewed-by: Jagan Teki <jteki@openedev.com>
[trini: Re-migrate, update common/console.c logic]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
Revise config to CONFIG_ROCKCHIP_RK3288_PINCTRL.
Signed-off-by: Ziyuan Xu <jk.kernel@gmail.com>
Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com>
evb-3288 board RK3288-based development board with 2 USB ports, HDMI,
VGA, micro-SD card, audio, WiFi and Gigabit Ethernet. It also includes
on-board 8G eMMC and 2GB of SDRAM. Expansion connector provide access to
display pins, I2C, SPI, UART and GPIOs. This add some basic files
required to allow the board to output serial messaged and can run
command(mmc info etc).
evb-rk3288 also supports booting from eMMC or SD card, the default is eMMC.
