path: root/configs/evb-px5_defconfig
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-08configs: Resync with savedefconfigTom Rini
2017-08-13rockchip: set Pre-reloc malloc pool size to 4kb for rk3368 based boardsAndy Yan
The default 1kb pre-reloc malloc pool is not enough for dm core to enable the dm-pre-reloc device drivers. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07rockchip: rk3368: Add PX5 Evaluation boardAndy Yan
PX5 EVB is designed by Rockchip for automotive field with integrated CVBS (TP2825) / MIPI DSI / CSI / LVDS HDMI video input/output interface, audio codec ES8396, WIFI / BT (on RTL8723BS), Gsensor BMA250E and light&proximity sensor STK3410. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
