The "cmd/Kconfig" has a TODO description for CMD_MISC that it should
really be named as CMD_SLEEP. Change it in the whole source tree.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- dts clean up to use -u-boot for px30, rk3399 boards
- dts sycn from upstream kernel for rk3328, rk3399
- add rockchip rng driver
- new board support: rk3328-roc-cc, rk3399-roc-pc,Nanopi M4 2GB
CONFIG_RNG_ROCKCHIP/CONFIG_DM_RNG is enabled.
Signed-off-by: Lin Jinhan <troy.lin@rock-chips.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Rockchip use CONFIG_SPL_OPTEE for OPTEE support, which is load and run
before U-Boot, but not use CONFIG_OPTEE which is after U-Boot.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
The px30 evb is an evaluation board for the px30 together with a dsi-
connected display. This adds board and config files for it.
Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com>
