path: root/configs/evb-ast2500_defconfig
2017-05-08aspeed: Enable I2C in EVB defconfigmaxims@google.com
Enable I2C driver in ast2500 Eval Board defconfig. Also enable i2c command. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Enable Pinctrl Driver in AST2500 EVBmaxims@google.com
Enable Pinctrl Driver in AST2500 Eval Board's defconfig Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Refactor AST2500 RAM Driver and Sysreset Drivermaxims@google.com
This change switches all existing users of ast2500 Watchdog to Driver Model based Watchdog driver. To perform system reset Sysreset Driver uses first Watchdog device found via uclass_first_device call. Since the system is going to be reset anyway it does not make much difference which watchdog is used. Instead of using Watchdog to reset itself, SDRAM driver now uses Reset driver to do that. These were the only users of the old Watchdog API, so that API is removed. This all is done in one change to avoid having to maintain dual API for watchdog in between. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28aspeed: Support for ast2500 Eval Boardmaxims@google.com
ast2500 Eval Board device tree and board specific configuration. Reviewed-by: Simon Glass <sjg@chromium.org>
