Switch DTB provider form OF_EMBED to OF_SEPARATE
to avoid the compile warning message:
==================== WARNING ======================
CONFIG_OF_EMBED is enabled. This option should only
be used for debugging purposes. Please use
CONFIG_OF_SEPARATE for boards in mainline.
See doc/README.fdt-control for more info.
Signed-off-by: Chia-Wei, Wang <chiawei_wang@aspeedtech.com>
Move the BOOTCOMMAND definition from the board inclusion
header to the default configuration file.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Bug fixes to mmc_spi
Add Aspeed SD driver
Fix dw_mmc timeout calculation
Fix timeout values passed to mmc_wait_dat0
sdhci dt caps/mask update
[trini: Fix evb-ast2500_defconfig CONFIG_MMC line]
Enable the MMC subsystem and the Aspeed SD controller. Also enable the
use of the device tree for probing the controller.
Signed-off-by: Eddie James <eajames@linux.ibm.com>
Reviewed-by: Cédric Le Goater <clg@kaod.org>
Tests in test/py/tests/test_env.py like this fail without CONFIG_HUSH_PARSER:
=> => printenv test_env_0
## Error: "test_env_0" not defined
=> .=> setenv test_env_0
=> => echo $test_env_0
$test_env_0
=> F
We also want a mac address so the ethernet device works in qemu.
Signed-off-by: Joel Stanley <joel@jms.id.au>
The aspeed board does not have an upstream MMC driver.
As CONFIG_MMC defaults on, the board would fail to build due to the
CONFIG_DM_MMC migration:
===================== WARNING ======================
This board does not use CONFIG_DM_MMC. Please update
the board to use CONFIG_DM_MMC before the v2019.04 release.
Failure to update by the deadline may result in board removal.
See doc/driver-model/MIGRATION.txt for more info.
Change the defconfig to disable MMC until a driver is submitted.
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig
parameters; only for the ARC architecture. This patch turns these two
parameters into Kconfig items everywhere else they are found.
All of the include/configs/* and defconfig changes in this patch are
for arm machines only. The Kconfig changes for arc, nds32, riscv,
and xtensa have been included since these symbols are found in code
under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined
include/configs/* or defconfigs for these architectures exist which
include these symbols.
These results have been confirmed with tools/moveconfig.py.
Acked-by: Alexey Brodkin <abrodkin@snopsys.com>
Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
[trini: Re-migrate for a few more boards]
The Faraday ftgmac100 MAC controllers as found on the Aspeed SoCs have
some slight differences in the HW interface (End-Of-Rx/Tx-Ring bits).
Signed-off-by: Cédric Le Goater <clg@kaod.org>
Reviewed-by: Joel Stanley <joel@jms.id.au>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Enable I2C driver in ast2500 Eval Board defconfig.
Also enable i2c command.
Signed-off-by: Maxim Sloyko <maxims@google.com>
Enable Pinctrl Driver in AST2500 Eval Board's defconfig
This change switches all existing users of ast2500 Watchdog to Driver
Model based Watchdog driver.
To perform system reset Sysreset Driver uses first Watchdog device found
via uclass_first_device call. Since the system is going to be reset
anyway it does not make much difference which watchdog is used.
Instead of using Watchdog to reset itself, SDRAM driver now uses Reset
driver to do that.
These were the only users of the old Watchdog API, so that API is
removed.
This all is done in one change to avoid having to maintain dual API for
watchdog in between.
ast2500 Eval Board device tree and board specific configuration.
