Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
in certain architectures. Migrate all config files.
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY
into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards.
Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to
not compile common/autoboot.c, as described in common/Makefile:
# This option is not just y/n - it can have a numeric value
ifdef CONFIG_BOOTDELAY
obj-y += autoboot.o
endif
It was a bit odd to enable/disable code with an integer type option,
but it was how this option worked before that commit, and several
boards actually unset it to opt out of the autoboot feature.
This commit adds a new bool option, CONFIG_AUTOBOOT, and makes
CONFIG_BOOTDELAY depend on it.
I chose "default y" for this option because most boards use the
autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that
had not set CONFIG_BOOTDELAY prior to the bad commit.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Espresso7420 is a development/evaluation board for Exynos7420 SoC. It
includes multiple onboard compoments (EMMC/Codec) and various
interconnects (USB/HDMI).
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
