path: root/configs/emsdp_defconfig
2019-11-01arc: emsdp/iotdk: Switch to DM_MMCAlexey Brodkin
Somehow EMSDP & IoT DK boards were skipped on ARC boads conversion to DM MMC. So doing it now. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2019-11-01arc: emsdp: Increase max FAT cluster sizeAlexey Brodkin
Some especially large SD-cards come from stock formatted with larger FAT cluster size so to accommodate those we just increase what we expect to have here in U-Boot given we have a plenty of space on EM SDP (16 MiB). Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2019-09-03arc: emsdp: Add initialization of PSRAMAlexey Brodkin
If the "Page Mode" is not enabled on the device, read operations from PSRAM may result in incorrect data. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2019-01-25ARC: Move ENV_SIZE and ENV_OFFSET to KconfigAlexey Brodkin
Join the party of some ARM boards and drop more items from include/configs/xxx.h. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-11-01emdk->emsdp: Rename boardAlexey Brodkin
Real marketing name of the board was recently updated so to accommodate that change renaming the board and all related to it. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
