path: root/configs/emlid_neutis_n5_devboard_defconfig
2019-07-15sunxi: move CONFIG_SPL_TEXT_BASE from *_defconfig to KconfigAndre Przywara
The choice of the SPL_TEXT_BASE is not really a decision that should be specified by each board's defconfig, as this setting is actually dictated by the SoC's memory map and the BootROM behaviour. To make this obvious and reduce the clutter in the defconfig files, let's specify the SoC constraints in the Kconfig stanza. This allows us to remove these lines from the defconfig files again. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-04-10arm: sunxi: Enable DRAM ODT by default on H3/H5Paul Kocialkowski
Most of the boards we support with H3/H5 enable DRAM on-die termination, which is consistent with the high DRAM clocks that are used. Make it the default (like it's done for other similar platforms) instead of defining it in each defconfig. Signed-off-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-01-18board: sun50i-h5: Add Emlid Neutis N5 supportAleksandr Aleksandrov
Emlid Neutis N5 is a SoM based on Allwinner H5, has a WiFi & BT module, DDR3 RAM and eMMC. - add neutis-devboard target to dtb makefile - add dtsi file for Neutis N5 needs - add config file for Neutis N5 Dev board Signed-off-by: Aleksandr Aleksandrov <aleksandr.aleksandrov@emlid.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> [jagan: update proper commit head] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
