path: root/configs/emlid_neutis_n5_devboard_defconfig
2019-04-10arm: sunxi: Enable DRAM ODT by default on H3/H5Paul Kocialkowski
Most of the boards we support with H3/H5 enable DRAM on-die termination, which is consistent with the high DRAM clocks that are used. Make it the default (like it's done for other similar platforms) instead of defining it in each defconfig. Signed-off-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-01-18board: sun50i-h5: Add Emlid Neutis N5 supportAleksandr Aleksandrov
Emlid Neutis N5 is a SoM based on Allwinner H5, has a WiFi & BT module, DDR3 RAM and eMMC. - add neutis-devboard target to dtb makefile - add dtsi file for Neutis N5 needs - add config file for Neutis N5 Dev board Signed-off-by: Aleksandr Aleksandrov <aleksandr.aleksandrov@emlid.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> [jagan: update proper commit head] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
