path: root/configs/efi-x86_payload32_defconfig
2019-12-04configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-02Convert CONFIG_SHOW_BOOT_PROGRESS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SHOW_BOOT_PROGRESS Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-24x86: efi-x86_payload: Enable PRE_CONSOLE_BUFFERBin Meng
Enable PRE_CONSOLE_BUFFER so that the full boot output can be viewed on the video console for the EFI payload. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-17x86: Add generic EFI payload supportBin Meng
It is possible to create a generic EFI payload for all x86 boards. The payload is configured to include as many generic drivers as possible. All stuff that touches low-level initialization are not allowed as such is the EFI BIOS's responsibility. Platform specific drivers (like gpio, spi, etc) are not included. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
