CONFIG_SYS_MONITOR_LEN
To do this, we set a default of 0 for everyone because there are a
number of cases where we define CONFIG_SYS_MONITOR_LEN but the only
impact is that we set TOTAL_MALLOC_LEN to be CONFIG_SYS_MALLOC_LEN +
CONFIG_ENV_SIZE, so we must continue to allow all boards to set this
value. Update the SPL code to use 200 KB as the default raw U-Boot size
directly, if we don't have a real CONFIG_SYS_MONITOR_LEN value.
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
CONFIG_SYS_MAXARGS
CONFIG_SYS_MONITOR_BASE
Note that for how this is re-used on some PowePC platforms, we introduce
CONFIG_SPL_SYS_MONITOR_BASE and CONFIG_TPL_SYS_MONITOR_BASE and use the
CONFIG_VAL macro to get the correct value at build time, in the code.
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
DM is the modern default approach for the drivers in U-Boot.
It also allows to configure code via Device Tree.
Move Intel Edison to use DM_USB_GADGET and drop hard coded values.
None of the driver for Edison is using DM_PCI_COMPAT, hence drop it.
SFI is quite poor and useless resource provider. Moreover it makes hard
to develop and extend functionality in the Linux kernel.
Enable a necessary minimum to use ACPI on Intel Edison.
Linux kernel have been prepared for this change since v5.4, where the last
crucial driver, i.e. for Basin Cove PMIC, has been submitted.
Note, that stock image won't suffer by this change since it doesn't have
ACPI enabled on the kernel level.
Enable command line editing, because it is extremely convenient.
The stock U-Boot on Intel Edison has timeout parameter for DFU command.
Enable it here to be compatible with the original U-Boot configuration.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
Enable SD slot on Intel Edison platform.
By default firmware doesn't put device on active state. Thus,
we have to do this explicitly.
Convert legacy driver to use watchdog class.
CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
There is no need for Intel Edison to have CONFIG_OF_EMBED to be enabled.
Replace it with CONFIG_OF_SEPARATE.
There is no functional change since u-boot.bin always contains DTB
either embedded or attached.
Tested-by: Ferry Toth <ftoth@exalondelft.nl>
Use defconfig instead of header file for CONFIG_CMD_PCI.
Move this option to Kconfig and tidy up the two boards which use it.
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This board does dwc3 gadget, not host, so we cannot have host support or
we will fail to link.
Let's imply the 'pci' command to access the de facto interconnect
bus in an x86 system.
At present we support multiple environment drivers but there is not way to
select between them at run time. Also settings related to the position and
size of the environment area are global (i.e. apply to all locations).
Until these limitations are removed we cannot really support more than one
environment location. Adjust the location to be a choice so that only one
can be selected. By default the environment is 'nowhere', meaning that the
environment exists only in memory and cannot be saved.
Also expand the help for the 'nowhere' option and move it to the top since
it is the default.
[trini: Move all of the imply logic to default X if Y so it works again]
Convert the pci_mmc driver over to driver model and migrate all x86 boards
that use it.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
[bmeng: remove DM_MMC from edison_defconfig]
Imply Tangier-specific drivers in the platform Kconfig.
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Now that all x86 boards have been converted to use DM, we can imply
these uclass drivers (DM_ETH, DM_RTC, DM_USB, DM_VIDEO) from the
top level.
Previously DM_GPIO, DM_KEYBOARD, DM_SERIAL, DM_SPI, DM_SPI_FLASH
are selected. Change to use 'imply' to allow them to be removed.
Note with this change, chromebook_link64 build fails:
common/built-in.o:(.data.env_htab+0xc): undefined reference to 'env_flags_validate'
lib/built-in.o: In function `hsearch_r':
lib/hashtable.c:380: undefined reference to 'env_callback_init'
lib/hashtable.c:382: undefined reference to 'env_flags_init'
make[1]: *** [spl/u-boot-spl] Error 1
CONFIG_SPL_ENV_SUPPORT is required for chromebook_link64 to build
again. This is just a workaround as it is not needed at all. See
commit bda40d5 "x86: qemu: Add a config for 64-bit U-Boot" for
the same issue seen on QEMU 64-bit target.
