path: root/configs/eb_cpux9k2_ram_defconfig
2015-09-11arm: Remove eb_cpu9k2 and eb_cpu9k2_ram boardsSimon Glass
These board have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
