path: root/configs/ea20_defconfig
2017-05-31Kconfig: Finish migration of hashing commandsDaniel Thompson
Currently these (board agnostic) commands cannot be selected using menuconfig and friends. Fix this the obvious way. As part of this, don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v' and "we have a hashing command" as this makes the Kconfig logic odd. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> [trini: Re-apply, add imply for a few cases, run moveconfig.py, also migrate CRC32_VERIFY] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2014-08-30davinci: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Davinci board select menu to davinci/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="davinci"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com>
