path: root/configs/e2220-1170_defconfig
2019-06-05ARM: tegra: Enable position independent build for 64-bitThierry Reding
Note that U-Boot is always chainloaded from cboot starting with L4T release 28. cboot always loads U-Boot to a fixed address, so making the builds position independent isn't strictly necessary. However, position independent builds can be convenient because if U-Boot is ever loaded to an address different from its link address, it will still be able to boot. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2019-02-20Kconfig: tegra: Migrate USB_EHCI_TEGRAPeter Robinson
Migrate USB_EHCI_TEGRA from headers to Kconfig Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Marek Vasut <marex@denx.de> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Peter.Chubb@data61.csiro.au Cc: Lucas Stach <dev@lynxeye.de> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2019-02-20Kconfig: tegra: Migrate SYS_I2C_TEGRAPeter Robinson
Migrate SYS_I2C_TEGRA from headers to Kconfig Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Heiko Schocher <hs@denx.de> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Peter.Chubb@data61.csiro.au Cc: Lucas Stach <dev@lynxeye.de> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-01tegra: Convert MMC to use driver model for operationsSimon Glass
Enable CONFIG_DM_MMC_OPS and CONFIG_BLK for all Tegra devices. This moves Tegra to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-16ARM: tegra: replace V_PROMPT define with kconfigStephen Warren
Commit 181bd9dc61d2 "kconfig: add config option for shell prompt" replaced define V_PROMPT with Kconfig option SYS_PROMPT. This crossed with patches adding Tegra T210 boards. Migrate the boards to the new scheme. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-06ARM: tegra: Add e2220-1170 boardStephen Warren
E2220-1170 is a Tegra210 bringup board with onboard SoC, DRAM, eMMC, SD card slot, HDMI, USB micro-B port, and sockets for various expansion modules. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
