path: root/configs/ds109_defconfig
2020-08-23Convert CONFIG_NETCONSOLE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_NETCONSOLE Signed-off-by: Tom Rini <trini@konsulko.com>
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-06-04Convert CONFIG_CMD_ASKENV et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CMD_ASKENV CONFIG_CMD_BMP CONFIG_CMD_BOOTD CONFIG_CMD_CACHE CONFIG_CMD_CRC32 CONFIG_CMD_DHCP CONFIG_CMD_ENV CONFIG_CMD_EXPORTENV CONFIG_CMD_EXT2 CONFIG_CMD_EXT4 CONFIG_CMD_FLASH CONFIG_CMD_FS_GENERIC CONFIG_CMD_FUSE CONFIG_CMD_GPIO CONFIG_CMD_GPT CONFIG_CMD_GREPENV CONFIG_CMD_I2C CONFIG_CMD_IMLS CONFIG_CMD_IMPORTENV CONFIG_CMD_LOADB CONFIG_CMD_LOADS CONFIG_CMD_MEMINFO CONFIG_CMD_MII CONFIG_CMD_MTDPARTS CONFIG_CMD_NAND CONFIG_CMD_NAND_TRIMFFS CONFIG_CMD_NFS CONFIG_CMD_PCA953X CONFIG_CMD_PCA953X_INFO CONFIG_CMD_PCI CONFIG_CMD_PING CONFIG_CMD_READ CONFIG_CMD_SF CONFIG_CMD_SPI CONFIG_CMD_SPL CONFIG_CMD_SPL_WRITE_SIZE CONFIG_CMD_TIME CONFIG_CMD_TRACE CONFIG_CMD_UBI CONFIG_CMD_UBIFS CONFIG_CMD_UNZIP CONFIG_FS_EXT4 Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-15rename symbol: CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOODTrevor Woerner
Have this symbol follow the pattern of all other such symbols. This patch also removes a TODO from the code. Reviewed-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD is compiled when there is a SPI NOR flash using MTDMiquel Raynal
MTD must be enabled when there is a SPI NOR flash using the SPI_FLASH_MTD config entry. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-12ARM: kirkwood: enable CONFIG_DM_USB for ds109Chris Packham
Enable CONFIG_DM_USB and CONFIG_BLK. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2018-11-30arm: kirkwood: configs: ds109: Convert to DM_SPIChris Packham
Enable CONFIG_DM_SPI=y and CONFIG_DM_SPI_FLASH=y in the defconfig. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-07configs: kirkwood: Move RTC_MV to DM and KconfigChris Packham
Now that there is DM support in the RTC_MV driver update board configs to use it. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-07configs: kirkwood: ds109: switch to DM_I2CChris Packham
Enable DM_I2C and I2C_MVTSWI for the ds109 board. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-29ARM: kirkwood: Add device-tree for ds109Chris Packham
Import the dts files from Linux 4.17 and enable CONFIG_OF_CONTROL. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14net: add Kconfig for MVGBEChris Packham
Add Kconfig for MVGBE and update boards to select this. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2018-01-22fs: Migrate ext4 to KconfigTuomas Tynkkynen
Migrate the following symbols to Kconfig: CONFIG_FS_EXT4 CONFIG_EXT4_WRITE The definitions in config_fallbacks.h can now be expressed in Kconfig. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-12-12ata: Migrate CONFIG_MVSATA_IDE to KconfigTuomas Tynkkynen
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09arm: kirkwood: add support for Synology DS109 boardWalter Schweizer
Synology DS109 is based on MV88F6281. The code is based on Dreamplug code with modificatons from Synologys open source repository. Signed-off-by: Walter Schweizer <swwa@users.sourceforge.net> Signed-off-by: Stefan Roese <sr@denx.de>
