path: root/configs/ds109_defconfig
2016-10-09arm: kirkwood: add support for Synology DS109 boardWalter Schweizer
Synology DS109 is based on MV88F6281. The code is based on Dreamplug code with modificatons from Synologys open source repository. Signed-off-by: Walter Schweizer <swwa@users.sourceforge.net> Signed-off-by: Stefan Roese <sr@denx.de>
