path: root/configs/dragonboard410c_defconfig
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-13configs: Resync with savedefconfigTom Rini
2018-09-30DB410c: Enable fastboot supportRamon Fried
Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-09-30configs: db410c: Enable USB PHYRamon Fried
Enable USB PHY driver. Also fixed the alphabetically ordering of the config. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-13db410c: add FIT supportRamon Fried
1. Add FIT support for DB410c defconfig. 2. Don't overwrite bootargs (they're already defined in Linux device tree for DB410c. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-05-26mach-snapdragon: Introduce pinctrl driverRamon Fried
This patch adds pinmux and pinctrl driver for TLMM subsystem in snapdragon chipsets. Currently, supporting only 8016, but implementation is generic and 8096 can be added easily. Driver is using the generic dt-bindings and doesn't introduce any new bindings (yet). Signed-off-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-02-10configs: Resync with savedefconfigTom Rini
2018-01-15db410c: use the device tree parsed by the lk loader.Jorge Ramirez-Ortiz
We dont need to keep copies of the properties that we are going to fixup since we will be using the dtb provided by the firmware. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-01-15db410c: replace reset driver with psciJorge Ramirez-Ortiz
this should be the norm for armv8 platforms. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-01-15db410c: update wlan and bt mac addresses from firmwareJorge Ramirez-Ortiz
The firmware that runs before u-boot modifies u-boot's device tree adding the local-mac-address and local-bd-address properties for the compatibles "qcom,wcnss-bt" and "qcom,wcnss-wlan". This commit reads that firmware, retrieves the properties and fixups the device tree that is passed to the kernel before booting. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-12-18configs: Resync with savedefconfigTom Rini
2017-11-17configs: dragonboard410c: Save environment data on eMMCJorge Ramirez-Ortiz
Save the environment data at the end of the boot partition on emmc Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-10configs: Resync defconfigsTom Rini
2017-07-0696boards: dragonboard/hikey: add device tree overlay supportPeter Robinson
96boards CE devices such as the DragonBoard and Hikey devices have numerous mezzanine options some of which need overlays from the beginning so it makes sense to enable device tree overlays. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2017-03-17configs: move CMD_MD5SUM definition to defconfigsAndre Przywara
Boards with an apparent need for the md5sum command had the connected config symbol defined in their board header file. Move this over to the respective defconfig files now that md5sum is configured via Kconfig. (This is a manual effort, which differs from moveconfig.py, not sure who is right here. Boards except sandbox loose the md5sum command with moveconfig.py, though it was explicitly mentioned in their config.h's) Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: migrate stih410-b2260] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-08cmd: move CONFIG_CMD_UNZIP and CONFIG_CMD_ZIP to KconfigMasahiro Yamada
CONFIG_CMD_ZIP is not defined by any board. I am moving CONFIG_CMD_UNZIP to defconfig files except UniPhier SoC family. I am the maintainer of UniPhier platform, so I know "select CMD_UNZIP" is better for this platform. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
2017-01-31mmc: msm: rename CONFIG_MSM_SDHCI to CONFIG_MMC_SDHCI_MSMMasahiro Yamada
Make the naming scheme consistent; all SDHCI-base drivers prefixed with CONFIG_MMC_SDHCI_. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-11dm: mmc: Move dragonboard410c to use CONFIG_BLK and CONFIG_DM_MMC_OPSSimon Glass
Update this board to use driver model for block devices and MMC operations. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-26Rename reset to sysresetStephen Warren
The current reset API implements a method to reset the entire system. In the near future, I'd like to introduce code that implements the device tree reset bindings; i.e. the equivalent of the Linux kernel's reset API. This controls resets to individual HW blocks or external chips with reset signals. It doesn't make sense to merge the two APIs into one since they have different semantic purposes. Resolve the naming conflict by renaming the existing reset API to sysreset instead, so the new reset API can be called just reset. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-04-01board: Add Qualcomm Dragonboard 410C supportMateusz Kulikowski
This commit add support for 96Boards Dragonboard410C. It is board based on APQ8016 Qualcomm SoC, complying with 96boards specification. Features (present out of the box): - 4x Cortex A53 (ARMv8) - 2x USB Host port - 1x USB Device port - 4x LEDs - 1x HDMI connector - 1x uSD connector - 3x buttons (Power, Vol+, Vol-/Reset) - WIFI, Bluetooth with integrated antenna - 8GiB eMMC U-Boot boots chained with fastboot in 64-bit mode. For detailed build instructions see readme.txt in board directory. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Tested-by: Simon Glass <sjg@chromium.org>
