path: root/configs/dra7xx_hs_evm_defconfig
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-15Kconfig: Rename CONFIG_SPL_DMA_SUPPORT to CONFIG_SPL_DMAVignesh Raghavendra
Rename CONFIG_SPL_DMA_SUPPORT to CONFIG_SPL_DMA. This allows to use macros such as CONFIG_IS_ENABLED() that allow conditional compilation of code for SPL and U-Boot. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-12-13arm: ti: dra7: move BOOTP_DNS2 and PHY_TI in defconfigGrygorii Strashko
Move BOOTP_DNS2 and PHY_TI from dra7xx_evm.h to dra7xx_evm_defconfig. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-12defconfigs: Migrate CONFIG_SYS_REDUNDAND_ENVIRONMENTTom Rini
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-25configs: dra7xx_evm: Increase the size of SPL_MULTI_DTB_FITFaiz Abbas
Expand SPL_MULTI_DTB_FIT to accommodate usb peripheral nodes being added to support SPL_DFU bootmode. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-10-25configs: dra7xx_evm: Add Kconfigs for SPL_DFU bootmodeFaiz Abbas
Enable configs for supporting SPL_DFU bootmode. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-08-25Convert CONFIG_SYS_SPI_U_BOOT_OFFS to KconfigHannes Schmelzer
This converts the following to Kconfig: CONFIG_SYS_SPI_U_BOOT_OFFS Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> [trini: Expose this for SPL_SPI_SUNXI for now] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-04-12configs: ti_omap5_common: Add NAND environment settingsFaiz Abbas
Now that NAND is supported on DRA71x include various NAND environment settings Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-12configs: dra71x-evm: Add Support for NANDFaiz Abbas
Add NAND support to dra71x-evm defconfig Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-03-22configs: dra7xx_evm: Remove ENV_IS_IN_FATFaiz Abbas
With U-boot supporting environment in multiple places, enable only ENV_IS_IN_EMMC Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-09defconfigs: dra7xx_hs_evm: Sync HS and non-HS defconfigsAndrew F. Davis
Additions have been made to the non-HS defconfig without the same being made to the HS defconfig, sync them. Signed-off-by: Andrew F. Davis <afd@ti.com>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-10Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
- DM_I2C_COMPAT removal for all ti platforms from Jean-Jacques Hiblot - Fix in i2c command help output from Chirstoph Muellner.
2018-12-10configs: am335x: am57x: dra7x: Enable CONFIG_SPL_DM_SEQ_ALIASJean-Jacques Hiblot
Those platforms need CONFIG_SPL_DM_SEQ_ALIAS because they enable both DM_I2C and SPL_DM. Without CONFIG_SPL_DM_SEQ_ALIAS, it is not possible to get the I2C bus with i2c_get_chip_for_busnum(). Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Felix Brack <fb@ltec.ch> Tested-by: Felix Brack <fb@ltec.ch> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2018-12-07configs: enable DM_USB and DM_USB_DEV for all DRA7 platformsJean-Jacques Hiblot
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-05-30usb: fastboot: Convert USB f_fastboot to shared fastbootAlex Kiernan
Convert USB fastboot code to use shared fastboot protocol. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-30fastboot: Move fastboot to drivers/fastbootAlex Kiernan
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to drivers/fastboot. Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing behaviour. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-13configs: dra7xx_evm/dra7xx_hs_evm: Enable AHCI and PIPE3Jean-Jacques Hiblot
Those options are required to enable support for SATA on DRA7 platforms. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08Migrate CONFIG_DRIVER_TI_CPSW to KconfigAlex Kiernan
This converts CONFIG_DRIVER_TI_CPSW to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-19configs: dra7xx_evm/dra7xx_hs_evm: Enable MMC HS200 and SD UHS supportJean-Jacques Hiblot
By default UHS and HS200 are not enabled. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-22Convert CONFIG_OMAP_USB_PHY to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP_USB_PHY Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-03cmd: fastboot: Rework fastboot dependencyMaxime Ripard
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right. That will also reduce the boilerplate in the defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-29TI: ARCH_OMAP2PLUS: Enable SPL_STACK_R and provide default valueTom Rini
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be, and that it is safe to use SPL_STACK_R and provide a default value for it. select this and re-sync the defconfigs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-11board: ti: dra76: Add dt supportLokesh Vutla
Add support for selecting proper dtb for dra76x u-boot from FIT. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
