path: root/configs/dra7xx_hs_evm_defconfig
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-10Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
- DM_I2C_COMPAT removal for all ti platforms from Jean-Jacques Hiblot - Fix in i2c command help output from Chirstoph Muellner.
2018-12-10configs: am335x: am57x: dra7x: Enable CONFIG_SPL_DM_SEQ_ALIASJean-Jacques Hiblot
Those platforms need CONFIG_SPL_DM_SEQ_ALIAS because they enable both DM_I2C and SPL_DM. Without CONFIG_SPL_DM_SEQ_ALIAS, it is not possible to get the I2C bus with i2c_get_chip_for_busnum(). Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Felix Brack <fb@ltec.ch> Tested-by: Felix Brack <fb@ltec.ch> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2018-12-07configs: enable DM_USB and DM_USB_DEV for all DRA7 platformsJean-Jacques Hiblot
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-05-30usb: fastboot: Convert USB f_fastboot to shared fastbootAlex Kiernan
Convert USB fastboot code to use shared fastboot protocol. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-30fastboot: Move fastboot to drivers/fastbootAlex Kiernan
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to drivers/fastboot. Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing behaviour. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-13configs: dra7xx_evm/dra7xx_hs_evm: Enable AHCI and PIPE3Jean-Jacques Hiblot
Those options are required to enable support for SATA on DRA7 platforms. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08Migrate CONFIG_DRIVER_TI_CPSW to KconfigAlex Kiernan
This converts CONFIG_DRIVER_TI_CPSW to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-19configs: dra7xx_evm/dra7xx_hs_evm: Enable MMC HS200 and SD UHS supportJean-Jacques Hiblot
By default UHS and HS200 are not enabled. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-22Convert CONFIG_OMAP_USB_PHY to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP_USB_PHY Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-03cmd: fastboot: Rework fastboot dependencyMaxime Ripard
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right. That will also reduce the boilerplate in the defconfigs. Reviewed-by: Ɓukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-29TI: ARCH_OMAP2PLUS: Enable SPL_STACK_R and provide default valueTom Rini
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be, and that it is safe to use SPL_STACK_R and provide a default value for it. select this and re-sync the defconfigs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-11board: ti: dra76: Add dt supportLokesh Vutla
Add support for selecting proper dtb for dra76x u-boot from FIT. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-26arm: dra7xx: Define Android boot argumentsSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-31ti: Default to ENV_IS_IN_FAT if MMC_OMAP_HSTom Rini
When we have MMC available we assume that we want to put the env as a file on FAT. Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25configs: Resync with savedefconfigTom Rini
2017-05-09defconfig: dra7xx_evm: enable CONFIG_BLK and disk driver model for SCSIJean-Jacques Hiblot
Enable disk driver model for dra7xx_evm as dwc_ahci supports driver model. As a consequence we must also enable CONFIG_BLK and CONFIG_DM_USB. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Dropped CONFIG_SPL_PHY=y in sandbox_spl to fix build error: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-08configs: dra7xx: Enable TI_COMMON_CMD_OPTIONSLokesh Vutla
Enable TI_COMMON_CMD_OPTIONS on all dra7xx platforms. Also sync with savedefconfig. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-05-08arm: usb: dra7xx: xHCI registers based on USB port indexUri Mashiach
Modify the determination of the base address of xHCI registers of DRA7XX targets. Before the commit: by the target. After the commit: by the USB port index. Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Roger Quadros <rogerq@ti.com> Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Roger Quadros <rogerq@ti.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27Kconfig: Enable FIT support by default for TI platformsAndrew F. Davis
Almost all TI defconfigs enable this already, add this as a default and remove the explicit assignment. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-09defconfigs: dra7xx_hs_evm: Move OPTEE load address to avoid overlapsMisael Lopez Cruz
Move the OPTEE load address to 0xbdb00000 in order to avoid overlap with the memory regions used in radio and RVC usecases. Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com>
2017-04-08defconfigs: dra7xx_hs_evm: Sync HS and non-HS defconfigsAndrew F. Davis
Additions have been made to the non-HS defconfig without the same being made to the HS defconfig, sync them. Signed-off-by: Andrew F. Davis <afd@ti.com>
2017-03-21configs: dra7xx_evm: Enable SPL_DMLokesh Vutla
Enable SPL_DM on all DRA7 based platforms. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
