CONFIG_BOARD_EARLY_INIT_F
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Move (and rename) the following CONFIG options to Kconfig:
CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI)
CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS)
CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC)
CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS)
CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA)
CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI)
They are the same option names as used in Linux.
This commit was created as follows:
[1] Rename the options with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e '
s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g
s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g
s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g
s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g
s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g
s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g
[2] Commit the changes
[3] Create entries in driver/mmc/Kconfig.
(copied from Linux)
[4] Move the options with the following command
tools/moveconfig.py -y -r HEAD \
MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI
[5] Sort and align drivers/mmc/Makefile for readability
Currently we let U-Boot find a spot at the end of DRAM at runtime, this
forces us to build an OPTEE image based on the size of DRAM for an EVM.
Add a default address that works across all current DRA7xx EVMs.
Signed-off-by: Andrew F. Davis <afd@ti.com>
DRA71-evm uses LP873x regulator. Enable lp873x PMIC config options.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Enable pmic/regulator config options.
Enable DM_ETH for hs boards.
Add DT support for dra71-evm and built it as part of FIT image.
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
These two options go together and it is best to do the conversion in one
step. So enable DM_MMC_OPS by default if DM_MMC is enabled.
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is
enabled.
Now that fastboot options are available in Kconfig, we can migrate them
from DRA7 header to corresponding DRA7 defconfigs.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Enable the platform-specific post-processing of FIT-extracted blobs such
as Kernel, DTB, and initramfs on TI DRA7xx high-security (HS) devices
which will ultimately invoke a ROM-based API call that performs secure
processing such as blob authentication.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
Enable DM based regulator framework and also fixed regulator support as
some IPs like mmc use regulators for there functioning.
Signed-off-by: Vignesh R <vigneshr@ti.com>
On DRA7, pcf chip present at address 0x21 on i2c1, is used to
switch between cpsw slave0 and slave1. Hence, enable PCF
driver for the same.
Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
Enable i2c driver model for dra7xx_hs_evm as omap i2c
supports driver model.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Modify the SPL build procedure for AM57xx and DRA7xx high-security (HS)
device variants to create a secure u-boot_HS.img FIT blob that contains
U-Boot and DTB artifacts signed with a TI-specific process based on the
CONFIG_TI_SECURE_DEVICE config option and the externally-provided image
signing tool.
Also populate the corresponding FIT image post processing call to be
performed during SPL runtime.
Signed-off-by: Daniel Allred <d-allred@ti.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Use a single defconfig for all DRA7xx hs platforms by enabling FIT and delete
the platform specific defconfigs.
