path: root/configs/dra7xx_evm_qspiboot_defconfig
2015-08-12dra7xx: Move CONS_INDEX to Kconfig and enable CONFIG_SPL_STACK_ADDRTom Rini
- Move the CONS_INDEX selection out of CONFIG_SYS_EXTRA_OPTIONS and into Kconfig proper. - While in here, enable CONFIG_SPL_STACK_ADDR Signed-off-by: Tom Rini <trini@konsulko.com>
2014-08-30omap5: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP5 board select menu to omap5/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap5"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com>
