path: root/configs/dra7xx_evm_defconfig
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-19configs: dra7xx_evm/dra7xx_hs_evm: Enable MMC HS200 and SD UHS supportJean-Jacques Hiblot
By default UHS and HS200 are not enabled. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-22Convert CONFIG_OMAP_USB_PHY to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP_USB_PHY Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-03cmd: fastboot: Rework fastboot dependencyMaxime Ripard
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right. That will also reduce the boilerplate in the defconfigs. Reviewed-by: Ɓukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-29TI: ARCH_OMAP2PLUS: Enable SPL_STACK_R and provide default valueTom Rini
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be, and that it is safe to use SPL_STACK_R and provide a default value for it. select this and re-sync the defconfigs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-11board: ti: dra76: Add dt supportLokesh Vutla
Add support for selecting proper dtb for dra76x u-boot from FIT. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-26arm: dra7xx: Define Android boot argumentsSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2017-08-11Convert CONFIG_CMD_SPL to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL Note that trats does not actually use SPL, so this option can no-longer be set. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-31ti: Default to ENV_IS_IN_FAT if MMC_OMAP_HSTom Rini
When we have MMC available we assume that we want to put the env as a file on FAT. Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-11qspi: dra7xx: enable qspi-boot for dra7x paltformB, Ravi
Enables qspi boot configuration for dra7xx platform. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-05-09defconfig: dra7xx_evm: enable CONFIG_BLK and disk driver model for SCSIJean-Jacques Hiblot
Enable disk driver model for dra7xx_evm as dwc_ahci supports driver model. As a consequence we must also enable CONFIG_BLK and CONFIG_DM_USB. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Dropped CONFIG_SPL_PHY=y in sandbox_spl to fix build error: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-08configs: dra7xx: Enable TI_COMMON_CMD_OPTIONSLokesh Vutla
Enable TI_COMMON_CMD_OPTIONS on all dra7xx platforms. Also sync with savedefconfig. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-05-08arm: usb: dra7xx: xHCI registers based on USB port indexUri Mashiach
Modify the determination of the base address of xHCI registers of DRA7XX targets. Before the commit: by the target. After the commit: by the USB port index. Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Roger Quadros <rogerq@ti.com> Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Roger Quadros <rogerq@ti.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27Kconfig: Enable FIT support by default for TI platformsAndrew F. Davis
Almost all TI defconfigs enable this already, add this as a default and remove the explicit assignment. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-03-21configs: dra7xx_evm: Enable SPL_DMLokesh Vutla
Enable SPL_DM on all DRA7 based platforms. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-12-04configs: dra7xx: Enable lp873x optionsKeerthy
DRA71-evm uses LP873x regulator. Enable lp873x PMIC config options. Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-04configs: dra7xx: Enable pmic/regulator optionsLokesh Vutla
Enable pmic/regulator config options. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-04ARM: dts: dra71x-evm: Add DT supportLokesh Vutla
Add DT support for dra71-evm and built it as part of FIT image. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-10-11configs: dra7xx_evm_defconfig: Enable PALMAS optionsKeerthy
Enable palmas PMIC config options. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-08ARM: dts: dra72: add rev C evm supportMugunthan V N
Add DTS support for dra72 evm Rev C which has the following changes * Two ethernet ports now instead of the single one in rev B. * DP83867 ethernet phy instead of DP838865. Cc: Vignesh R <vigneshr@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-07arm: dra7xx: Move fastboot options to defconfigSemen Protsenko
Now that fastboot options are available in Kconfig, we can migrate them from DRA7 header to corresponding DRA7 defconfigs. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-10-06configs: dra7xx_evm_defconfig: Enable LPAE modeKeerthy
Enable Linear Physical Address Extension mode which is a prerequisite for hypervisor mode. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-20configs: Re-syncTom Rini
