Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
Enable palmas PMIC config options.
Signed-off-by: Keerthy <j-keerthy@ti.com>
These two options go together and it is best to do the conversion in one
step. So enable DM_MMC_OPS by default if DM_MMC is enabled.
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is
enabled.
Add DTS support for dra72 evm Rev C which has the following
changes
* Two ethernet ports now instead of the single one in rev B.
* DP83867 ethernet phy instead of DP838865.
Cc: Vignesh R <vigneshr@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Now that fastboot options are available in Kconfig, we can migrate them
from DRA7 header to corresponding DRA7 defconfigs.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Enable Linear Physical Address Extension mode which is a
prerequisite for hypervisor mode.
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Enable eth driver model for dra7xx_evm as cpsw supports
driver model.
This was already added with the commit 641b936fa5ba but with
commit bd7245849f7c to add fit support CONFIG_DM_ETH was missed.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Enable DM based regulator framework and also fixed regulator support as
some IPs like mmc use regulators for there functioning.
Signed-off-by: Vignesh R <vigneshr@ti.com>
On DRA7, pcf chip present at address 0x21 on i2c1, is used to
switch between cpsw slave0 and slave1. Hence, enable PCF
driver for the same.
Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
Enable i2c driver model for dra7xx_evm as omap i2c
supports driver model.
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Create an entry for "config USB_XHCI_DWC3" in Kconfig and
switch over to it for all boards.
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
Use a single defconfig for all DRA7 platforms by enabling FIT and delete
the platform specific defconfigs.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
And also reformat defconfigs using "make savedefconfig" rule.
Description was borrowed from kernel dwc3 Kconfig.
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
NFS loading works on DRA7 variants, remove the undefinition.
Signed-off-by: Andrew F. Davis <afd@ti.com>
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
There are already Kconfig options for SPI drivers, but we
commit does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
- Move the CONS_INDEX selection out of CONFIG_SYS_EXTRA_OPTIONS and
into Kconfig proper.
- While in here, enable CONFIG_SPL_STACK_ADDR
This commit moves:
- CONFIG_SPI_FLASH_BAR
from include/configs/*.h into configs/*_defconfigs
Signed-off-by: Jagan Teki <jteki@openedev.com>
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Since commit e02ee2548afe (kconfig: switch to single .config
configuration), the prefixes in defconfig files such as "+S:",
"+ST:", etc., are meaningless.
This commit was generated by the following command:
find configs -name '*_defconfig' | xargs sed -i 's/^+*S*T*://'
Becuase the board select menu in arch/arm/Kconfig is too big,
move the OMAP5 board select menu to omap5/Kconfig.
Move also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="omap5").
Reviewed-by: Tom Rini <trini@ti.com>
