path: root/configs/dockstar_defconfig
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
